Sunday Sunshine - 17th March
- Has thanked: 20813 times
- Been thanked: 10484 times
Weather forecast was for hail and thundery showers for today, however as is with such unstable air streams the day will start off bright and clear before all of a sudden the clouds bubble up with force. I was out setup and observing by 9am.
First off I went to the blue end and got some CaK in as I knew the seeing was only going to go downhill through the observing session.
First off the full disk, 60mm f15, homebrew CaK filter and the PGR GH3 ICX814.
cak-60-fd-bw by Mark Townley, on Flickr
cak-60-fd-colour by Mark Townley, on Flickr
I tried some closeups with the 100mm scope somewhere over 2000mm fl with the PGR CH3.
cak-close-bw by Mark Townley, on Flickr
cak-close-colour by Mark Townley, on Flickr
At the other end of the spectrum it surprised me how much there was to see when looking closer in Ha. First off the full disk with the SM90 and ICX814.
Ha-Full-Disk-bw by Mark Townley, on Flickr
Ha-Full-Disk-colour by Mark Townley, on Flickr
Then popping the Quark in the end to double stack for a look at the filament and plage from relic active regions:
AR-closeup-Ha-bw by Mark Townley, on Flickr
AR-closeup-Ha-colour by Mark Townley, on Flickr
Be sure to double click and view in flickr for the full size images. Pleased to get some sun this morning as it's now just wet again.
- Has thanked: 1188 times
- Been thanked: 1382 times
Re: Sunday Sunshine - 17th March
Excellent images, Mark!
Your SM90II telescope looks like a keeper. And works even better with your Quark.
And CaK easily can be even better at about 1.5x larger scale!
Hope a good seeing came back.
- Has thanked: 8558 times
- Been thanked: 8290 times
Nice set of images, Mark. I see you were rain/hail dodging like myself.
Nice one Mark, is going to be a pleasure to image with this scope when the weather is better / the sun is more active.
Thanks everyone! I was undersampling Valery, I need to look at a more powerful barlow for CaK, I end up stacking barlows at the moment if I want to get up to >f30 which the extra glass really has an adverse effect on light levels. My 2.5x barlow gives me a annoying ghost at 393nm which rules it out. I need to get a decent 3x barlow.
The weather was awful today after 11am Stu, at one point the ground was totally covered in hail. I do like the scope / camera combo i'm running at the moment, I just need the seeing to improve so I can use some bigger apertures.
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Great set Mark. Didn't get chance for much more than a quick glance at white light today unfortunately.
David
- Been thanked: 4427 times
Hi Mark...
These Ha and CaK images are excellent...well done
- Has thanked: 9319 times
- Been thanked: 6157 times
Thanks everyone! Couple of extras here; the other limb in Ha showing a small prom and small plage area.
other-limb by Mark Townley, on Flickr
Was running through my CaK data I shot, this one was by far the sharpest. I will endeavour to get a higher f ratio next time Valery.
cak-close-3 by Mark Townley, on Flickr
- Been thanked: 4980 times
Mark:
Beautiful session, clean and crisp images all of them.
Cracking shots Mark I really enjoyed them all
We had hail from dawn till lunch, then rain from lunch till bed. I think we were in the horrible Irish sea / Cheshire gap stream
Thanks everyone! The adapter plate to double stack my nice 50mm etalon onto the SM90 is scheduled to arrive tomorrow! Woohoo! Looking forward to hopefully getting some clear skies this weekend now.
