Heya,
I was blessed with some lovely clear skies today, it's been 9 days since I last saw the sky with the overcast cloudy stormy mess that Florida seems to like to be these days. The seeing was not great, but it was adequate to at least attempt to use larger scales with and I managed to get a little bit of data on the notable features today, namely, the two active regions and the wonderful flaring sunspot in AR2736 that has evolved significantly since it showed up. I'm very much looking forward to seeing it round the limb and hopefully it remains active and grows a bit as it rounds the limb to see some really cool activity there since it has so many little poles and keeps flaring a bit. There's a few nice prominence fields and a rather large one on the limb. I was able to finally do a little white light imaging too, just in time for such a sunspot.
The large HA presentation of AR2735 & AR2736 is a 3 panel mosaic. The full disc was created with 2 panels stitched together.
B&W:
Colored:
Earth Scale:
Equipment:
Large Scale:
C8 Edge HD + Aires 200mm Tri-band D-ERF + Baader 2" UV/IR Block Filter
Daystar Quark Chromosphere
ASI174MM + 0.5x Focal Reducer
Full disc:
ST80 (Masked to 60mm) + Baader 2" UV/IR Block Filter
AR2735 & AR2736 & FD | HA & WL | March 22nd 2019
- Been thanked: 1390 times
- Been thanked: 1641 times
- Has thanked: 20908 times
- Been thanked: 10567 times
Re: AR2735 & AR2736 & FD | HA & WL | March 22nd 2019
These came out well Marty!
- Has thanked: 18062 times
- Been thanked: 8920 times
These are really nice Marty, especially the side by side shot
- Has thanked: 65 times
- Been thanked: 4447 times
Excellent image Marty...well done
- Has thanked: 9371 times
- Been thanked: 6195 times
WOW ! Great stuff, Marty. Very sharp and excellent processing...
- Has thanked: 8587 times
- Been thanked: 8322 times
There’s some beautiful complexity in that AR, Marty. Nicely imaged.
