Sun March 24th
- Has thanked: 9327 times
- Been thanked: 6163 times
Sun March 24th
Hello all: I was thrilled this morning to be back for a quick imaging session after three very intense months dealing with my mother's fall and serious spinal injury. The seeing was not great, but good enough for me to get at least one decent image after completely missing AR2736
I am also happy to see that with the weather improving, many solarchatters are out imaging this weekend...
Clear skies to all !
- 094905 final mono.jpg (408.13 KiB) Viewed 2053 times
- 094905 final color.jpg (640.62 KiB) Viewed 2053 times
- Has thanked: 20828 times
- Been thanked: 10502 times
Re: Sun March 24th
Sorry to hear about your mothers fall Franco. It is an excellent image though - taken with your 90mm?
- Been thanked: 4881 times
Re: Sun March 24th
Franco, hopefully your mother will recover quickly.
Very nice and detailed images.
Re: Sun March 24th
Thank you, Mark and Maurits, for your good wishes. The image was taken with the HaT scope, 0.7 reducer and a newly acquired Solar Spectrum filter. The seeing conditions were certainly not ideal for the HaT, but one image came out OK.
- IMG_0863.jpg (1.13 MiB) Viewed 2034 times
- IMG_0862.jpg (814 KiB) Viewed 2034 times
Re: Sun March 24th
Lovely setup Franco! Which solar spectrum etalon did you get in the end?
- Been thanked: 4981 times
Re: Sun March 24th
Franco:
Hope your mother recovers soon.
Very nice images and setup.
- Christopher
- Has thanked: 33 times
- Been thanked: 34 times
Re: Sun March 24th
Franco,
Nice images from a sweet set-up. Can't wait to see what the HAT 0.3A combo can do on a good day. Hope your mom is doing much better.
Christopher
Re: Sun March 24th
It's a beauty! On my want list!
- Has thanked: 8559 times
- Been thanked: 8297 times
Re: Sun March 24th
Good luck with your mother’s recovery.
Nice images. I’m looking forward to seeing more with that kit.
Re: Sun March 24th
Franco,
Great looking images and the equipment is fantastic. Steady skies will be the only requirement. I use a SO 1.5 like yours and am pleased with the performance. I am curious as to the temperature you operate it.
My best wishes to you Mom.
Phil
Phil
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Re: Sun March 24th
Hi Franco,
sorry to hear about your mother, whish here the best. It's good to see you'r imaging again. That is really a superb setup. If these images are taken under bad seeing, can't wait to see the good ones.
Rgrds,
Paul
Rgrds,
Paul
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Re: Sun March 24th
Excellent images, Franco, a fine setup. May I suggest to shield your mount from direct sunlight, under the Sun it becomes hot, heat goes to the tube and images suffer, particularly in a SC tube. This was my experience when I used a Celestron CGEM.
My best wishes for your mother's recovery.
Raf
Re: Sun March 24th
Thank you Phil, Paul, Raf and Maurits for your comments and kind words.
@Phil: for the time being the filter operates at 38 degrees as it came from the manufacturer. In the field it fluctuated between 37.9 and 38.1 degrees. Have you experimented with other settings ? Last Sunday was the very first time I tried the entire set up for imaging.
Re: Sun March 24th
Franco,
38 degrees, interesting. Mine has a 55° spec. and I found that by increasing the temperature a few more degrees the field luminosity is more uniform. These filters hold the set temperature very well. From the looks of your images, in my opinion, you have it set correctly.
Thanks,
Phil
Thanks,
Phil
- Been thanked: 8907 times
Re: Sun March 24th
Sorry to hear about your Mum Franco, I hope she is well on the way to a good recovery now.
The images are amazing, you are very lucky to have a SolarSpectrum
Re: Sun March 24th
Thank you Alexandra, for your good wishes and kind words..
Believe me I know how lucky I am. I had a to sell a large commercial building to afford this filter
