Quark Chromosphere vs Prominence model?
Ben Cartwright SASS
Been thanked: 2 times
Post by Ben Cartwright SASS »
Quark Chromosphere vs Prominence model.
I have the chromosphere, with the solar minimum and most of the "action" being on the limb, how much brighter and obvious are the proms when imaging with the Prominence model?
Is anyone using both?
Has thanked: 156 times
Been thanked: 893 times
Re: Quark Chromosphere vs Prominence model?
Post by Valery »
Jim,
If to compare with my three last Quarks (all Chromosphere models) then yes, Prominence model has significatntly brighter picture and promonences look more impressive. Especially faint disconnected which flying over the limb.
Has thanked: 1188 times
Been thanked: 1382 times
Post by MalVeauX »
Ben Cartwright SASS wrote: Fri Apr 05, 2019 12:45 pm Quark Chromosphere vs Prominence model.
Hi Ben,
Try using your Chromosphere model with a faster focal-ratio, F15~20, instead of the suggested F30+. The bandpass will widen for prominences.
MAURITS
Has thanked: 2464 times
Been thanked: 4880 times
Post by MAURITS »
Valery wrote: Fri Apr 05, 2019 1:26 pm Jim,
Valery, do you have an example image, recorded with the Quark prominence version?
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Ben Cartwright SASS
MalVeauX wrote: Fri Apr 05, 2019 6:40 pm
Hi Ben,
The only scope I have below f/6 is my st80 f/5 which would give me f/21 and can't get close, get 3/4 disks with it.
Post by Valery »
MAURITS wrote: Fri Apr 05, 2019 6:45 pm
No, I don't. I have compared the views vs the Prominence model owned by another fun of solar H-a observing.
This is really the advantage of the Prominence model. The images always can be adjusted. Not so easy in a visual observing.
