Quark Chromosphere vs Prominence model.
I have the chromosphere, with the solar minimum and most of the "action" being on the limb, how much brighter and obvious are the proms when imaging with the Prominence model?
Is anyone using both?
Quark Chromosphere vs Prominence model?
- Been thanked: 2 times
Re: Quark Chromosphere vs Prominence model?
Jim,
If to compare with my three last Quarks (all Chromosphere models) then yes, Prominence model has significatntly brighter picture and promonences look more impressive. Especially faint disconnected which flying over the limb.
- Has thanked: 1188 times
- Been thanked: 1382 times
Hi Ben,Ben Cartwright SASS wrote: ↑Fri Apr 05, 2019 12:45 pm Quark Chromosphere vs Prominence model.
Try using your Chromosphere model with a faster focal-ratio, F15~20, instead of the suggested F30+. The bandpass will widen for prominences.
Valery, do you have an example image, recorded with the Quark prominence version?
The only scope I have below f/6 is my st80 f/5 which would give me f/21 and can't get close, get 3/4 disks with it.MalVeauX wrote: ↑Fri Apr 05, 2019 6:40 pmHi Ben,Ben Cartwright SASS wrote: ↑Fri Apr 05, 2019 12:45 pm Quark Chromosphere vs Prominence model.
No, I don't. I have compared the views vs the Prominence model owned by another fun of solar H-a observing.
This is really the advantage of the Prominence model. The images always can be adjusted. Not so easy in a visual observing.
