Saturday Sun 6th April
- Has thanked: 8418 times
- Been thanked: 8162 times
Blue skies, but with enough haze to take some of the edge off hi-res imaging. The seeing wasn't great either. Anyhow, I persevered and here are some of the better images from my lunchtime session.
CaK, full disk
20190406_CaK_FD by Stuart Green, on Flickr
20190406_CaK_FD_Colour by Stuart Green, on Flickr
A closer view of AR2737 in CaK
20190406_CaK_AR2737 by Stuart Green, on Flickr
20190406_CaK_AR2737_Colour by Stuart Green, on Flickr
and in Ha
20190406_AR2737_Ha_Mono by Stuart Green, on Flickr
20190406_AR2737_Close_Ha_Mono by Stuart Green, on Flickr
Thanks for looking.
CaK, full disk
and in Ha
Thanks for looking.
- Has thanked: 20438 times
- Been thanked: 10245 times
Re: Saturday Sun 6th August
A great set Stu! The close up CaK came out really well. I had scudding cloud all afternoon yesterday so was imaging in the gaps, with roller coaster seeing resulting. Is the last image a crop from the 6" or with the RC? Pssst, guessing you meant april
April indeed....wishing my time away!marktownley wrote: ↑Sun Apr 07, 2019 7:36 am A great set Stu! The close up CaK came out really well. I had scudding cloud all afternoon yesterday so was imaging in the gaps, with roller coaster seeing resulting. Is the last image a crop from the 6" or with the RC? Pssst, guessing you meant april
Yes, just a crop. The conditions were not really up to hi-res.
- Been thanked: 4786 times
Re: Saturday Sun 6th April
Great images, considering the conditions! I was clouded out yesterday afternoon when I had just set up the scope.
Frank
Frank
Nice images, Stu.
BTW. When my 6" refractors delivers the images like this 20190406_AR2737_Ha_Mono then my C8 sure delivers better images and very often the C11 also works so well that I can obtain the resolution at it's limit! So, you need to try RC 10" more often.
My usual method is that if an aperture is sustained at Ha then I try that aperture in CaK, if it is still working in CaK then I up the aperture in Ha. Ad infinitum...
At my location I know well: the very first come the best seeing and then it worsens quite soon. So, if I like to image the sun in both lines, I do image in CaK first and after one, two or maximum thee successfull movies, I re-configure the telescope to Ha at the speed I can only work at in about 3-5 minutes.marktownley wrote: ↑Sun Apr 07, 2019 6:58 pm
And I never start with a smaller telescope. I always start with the largest and then acting according to the seeing.
- Has thanked: 9145 times
- Been thanked: 6025 times
Many thanks for your comments, guys.
I do need to try the RCT more often, Valery
I've got good at 'guessing' what the seeing will be like where I live, I fire up the SSM for a hand held view to confirm (or not) my gut feeling. My seeing is more often less good than good, and time is always precious - be it how much time I have available, or, how long till the next cloud spoils the view. If my data in 100mm at Ha is good I the try at CaK at 100mm, knowing if this too is successful there is a chance the 8" at Ha has a chance... I've tried starting off with the 8" in Ha but more often than not find myself backing down the aperture which wastes time setting up and down. Faster cameras later this year may change my approach, but at the moment I feel i've found the most efficient image capturing setup for where I live. I can understand why starting off large works when the seeing is better more often than it is worse.Valery wrote: ↑Mon Apr 08, 2019 12:54 amAt my location I know well: the very first come the best seeing and then it worsens quite soon. So, if I like to image the sun in both lines, I do image in CaK first and after one, two or maximum thee successfull movies, I re-configure the telescope to Ha at the speed I can only work at in about 3-5 minutes.marktownley wrote: ↑Sun Apr 07, 2019 6:58 pm
Unfortnately, this conclusion/understanding is wrong. My seeing is mainly poor to barely acceptable. The real reasons I always starting with the largest aperture are:marktownley wrote: ↑Tue Apr 09, 2019 7:49 pm I can understand why starting off large works when the seeing is better more often than it is worse.
1. best seeing is always between 20 and 30 degree of the sun evelation above the horizon.
2. largest aperture always give the most of what I wish from the solar imaging. So, why wasting the time for smaller telescopes?
3. somewhat worser seeing (late morning and then) can be still good enough for smaller instruments.
Of course, a fast camera is one of the key factors on the way to good results in hig res imaging of the sun. My present cameras are the fastest available for acceptable money today - Basler ASA1920-155 which gives >200fps with ROI 1580x1060 and ZWO ASI290MM which gives even higher speed. Basler is ideal for H-a imaging at a final F/20-25 (F/43 at the etalon) and ASI290MM is an ideal for the CaK at F/20 on the chip.
I hope that a fast camera will give you what you are looking for. Basler ASA1920-155 with a good quality cable is all you need for your main rig - C8HaT - standard Quark Chromo + 0,5x to 0,7x reducer(s).
Valery, your observation that seeing is best between 20 and 30 degrees agrees with my results in the last couple of days - I will try to confirm if that holds generally for my location, too. Is there an obvious reason/explanation for that?
- Been thanked: 4904 times
Stu;
Superb high resolution on the CaK closer view shots.
Best regards from N.Y.
Many thanks, Eric.
- Has thanked: 1171 times
- Been thanked: 1360 times
