Omega filters working at last
RodAstro
Has thanked: 153 times
Been thanked: 164 times
Post by RodAstro » Wed Apr 10, 2019 9:01 pm
Firstly thanks to all for your help, some I have asked for, the other I have gleaned from all the threads.
Anyway after more than twelve months of work I have managed to get Bob's filters to work
Firstly Bob's original filters had a bonded first filter (etalon) and blocker this caused many reflections internally and was almost unusable but I could see some potential. Bob kindly replaced the filters with two matched etalon type filters and a seperate blocking filter this worked much better and if all fails I could at least make a prominence viewer for my scope.
In the end the critical thing was not aligning the tilts and positions of the filters but the rigidity of the system.
Building a collimated beam ended up so long that as the scope tracked the whole system would flex a few microns and everything needed adjusting to bring it back on band, or building like the proverbial brick s**t house.
So I have gone back to an F30 beamand machined 2" diagonal and fittings to get the strength and keep everything supported well.
I am beginning to think the filters do not have a sweet spot but they do have banding.
This comes from processing the images I have taken where I have darkened the light bands and detail appears so with a little work with software I can flatten the image.
Visually I use two reverse CPL filters and cross them until I get a rid of the glare and can the see the surface detail and just remove one filter when viewing the prominences.
I am using a Zeiss 6" f15 coude and not many other filter systems will work easily with this scope and especially at the cost of Bob's filters.
I could have talked about the visual images I am getting but pictures are the best way to show how well it is working so here are the first, I do need a little more practice at processing but after all the mechanical work I have done that will be nothing to learn.
8-4-19 merged2.jpg (237.72 KiB) Viewed 731 times
10-4-19 4-15pm regy18stack Ps PSP flatend colour contrast (2).jpg (161.98 KiB) Viewed 731 times
8-4-19 Prom restack Ps PSP (2).jpg (46.4 KiB) Viewed 731 times
8-4-19 Rejistack Ps (2).jpg (43.3 KiB) Viewed 731 times
Has thanked: 2214 times
Been thanked: 856 times
Re: Omega filters working at last
Post by marktownley » Wed Apr 10, 2019 9:03 pm
Came out well there!
RodAstro
Post by RodAstro » Wed Apr 10, 2019 9:15 pm
Thanks Mark
I am pleased with the results.
The worst thing in my system is the seeing where I sit low down in a valley so not really conducive to good solar viewing so at this magnification I recon the system is working pretty well
The big plus for me though is my two ton coude telescope where I can sit in one position with no wobble and a bino head and concentrate on the image, also out of the sun, although I wish I had the sun on my back today, it was cold in the observatory
Post by marktownley » Wed Apr 10, 2019 9:33 pm
Sounds a nice scope. Any pickies to share?
RodAstro
Post by RodAstro » Wed Apr 10, 2019 9:50 pm
Hi Mark
A Pic of mine with a 10" F3.6 astrograph and a SW102 finder/autoguider
You can't really tell how big it is so the other picture is of the one in the Brisbane public observatory
It is my pride and joy
Brisbane Zeiss 6 inch.jpg (56.4 KiB) Viewed 720 times
RTs Zeiss 10 inch f3.6 astrograph 102mm auto guider.jpg (2.78 MiB) Viewed 720 times
RodAstro
Post by RodAstro » Wed Apr 10, 2019 10:03 pm
Don't know why it did that, maybe file size this is smaller
RTs Zeiss 10 inch f3.jpg (454.78 KiB) Viewed 719 times
Has thanked: 30 times
Been thanked: 107 times
Post by Valery » Thu Apr 11, 2019 4:14 am
The telescope is very good and the filters are bad. I got Omega H-a which is even worser then your's.
Bob Jonson, the Omega owner, is a typical scammer - he promised replacement or money back, but never responded.
RodAstro
Post by RodAstro » Thu Apr 11, 2019 7:26 am
Hi Valery
I must admit we did have to persist with Bob he is very slow to respond, not his day job. We have two sets of these filters and I am now going to make another setup for a friend. I think the first set he sent with the bonded front filter may have been done for safety but no one seems to have got them working. we then suggested a separate blocker and Bob was ok with that but they took a couple of months to arrive and was just a single set. Once I got somewhere with them a second set was replaced and they are of much better quality.
Sadly a lot of time was also spent in british customs probably four months in all.
Once working though they are impressive for proms and as I said I can't think of an easy way to get any other system working on this scope other than mabe pulling a quark apart and that becomes an expensive experiment.
The scope is lovely and a dream to use so solid that I get very frustrated with every other scope I use now
