AR12738 at High Res through 150mm refractor and QUARK Chromosphere.
Hi all,
April 11 morning was reither cloudy and foggy. However in two hours the sky cleared.
The seeing was average but with some improvements.So, I took my computer and Quark and
quickly set up the telescope.
Here is the best shot of the AR12738 I was able to take.
The telescope is SkyWatcher 150/750 equipped with the ARIES full aperture DERF, Quark Chromosphere and Basler ASA 1920-155 camera. A 2x TV PM barlow has been used to get F/43 at the etalon (remember that Quark has it's own build-in 4,3x telecentric barlow). F/43 at the etalon helps to keep etalon's bandwidth maximally narrow and so, best possible image contrast.
Thanks for looking.
Thanks for looking.
- AR12738-2019-04-11-SW150mm-ARIES-155mmDERF-UT09h-39m--QUARK-3cl-Basler1920-155.jpg (273.75 KiB) Viewed 1745 times
- Been thanked: 1624 times
Re: AR12738 at High Res through 150mm refractor and QUARK Chromosphere.
Good detail Valery. I saw this spot yesterday but its good to see it up close. Thanks, John W.
- Has thanked: 8558 times
- Been thanked: 8290 times
Nice one, Valery. Lots of fine detail.
How many Quarks did you get through before you got a good one?
- Has thanked: 20813 times
- Been thanked: 10484 times
This is an excellent capture Valery
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Hi Valery,
That is a very nice image, despite the weather. I am also keen to try using a Quark Chromosphere on my Celestron 150mm Omni XLT fitted with an ARIES D-ERF. Do you use a 2" 2X TV barlow immediately at the output of the telescope followed by the Quark Chromosphere? Any other adapter/spacers required in between? Can you show a side-view picture of the telescope with the Quark and Basler camera?
Thanks.
Alfred
Thanks.
Alfred
- Has thanked: 1188 times
- Been thanked: 1382 times
Lovely capture Valery!
Yes, correct. And no optics in between.
- Been thanked: 4427 times
That is an excellent image Valery...well done
It's uniformity is far from perfect. Visually the non-uniformity is relatively easily seen, especially when moving accross the sun disk.
It is very narrow, but not really uniform,
Thanks, Maurits.
That's a cracker Valery
