Friday morning was beautiful, although, as is so often the case, the seeing conditions were pretty poor with only the briefest of clear viewing. I shot through pretty much all of my SD memory to get something half decent across the spectrum from CaK to Ha.
Valery, I ran half my session on the 250mm RCT with nothing to show for my efforts in hi-res Ha...
Anyhow, first up, the proverbial FD in CaK (Altair Lightwave 72mm F6 with Lunt B600/K-Line/Omega filter stack). Basler acA2440-75um IMX250 with 1.5x Barlow.
20190412_CaK_FD_Mono by Stuart Green, on Flickr
20190412_CaK_FD_Colour by Stuart Green, on Flickr
The same filter setup with the Tecnosky 125/acA1920-155um on a 2.7x APM Barlow for a closer view of AR2738
20190412_AR2738_CaK_Mono by Stuart Green, on Flickr
20190412_AR2738_CaK_Colour by Stuart Green, on Flickr
I did manage to grab an image in 656nm red on the 250mm RCT, but narrow band hi-res was useless under the conditions.
20190412_656nm_Red_AR2738 by Stuart Green, on Flickr
I had more luck on my 150mm/DS Lunt 35 mod with the acA1920-155um IMX174 camera and 2.5x Powermate.
First up is a mosaic of four captures with quite a bit of overlap.
20190412_AR2738_Ha_Mono_Mosaic by Stuart Green, on Flickr
And a single pane capture
20190412_AR2738_Ha_Mono by Stuart Green, on Flickr
20190412_AR2738_Ha_Colour by Stuart Green, on Flickr
Thanks for looking.
Sun in Ha and CaK 12th April
- Has thanked: 8559 times
- Been thanked: 8290 times
- stef41
- Has thanked: 124 times
- Been thanked: 1490 times
- Has thanked: 1188 times
- Been thanked: 1382 times
Re: Sun in Ha and CaK 12th April
That looks beautiful Stu! And interesting to compare your CaK image with mine. Even the image scale is almost the same.
- Has thanked: 9319 times
- Been thanked: 6157 times
- Been thanked: 10489 times
Super set there Stu! I'm on my travels in Beddgelert for a week and have the little travelling setup in the back of the car so hoping to get some images at some point. Solar observing has already been minuted as an activity for today...
