from this morning before cloudcover rolled in. With the C8, but looking at seeing values, maybe should have taken the SW120 ...
Paul
AR2738 - April 13 2019
- Has thanked: 1313 times
- Been thanked: 64 times
- Been thanked: 4419 times
Re: AR2738 - April 13 2019
Nice shot Paul!!!
The light bridge grew through the day as well.
I finally managed to get the SSM plugin running today, so I'm eager to try it out the next sunny day.
- Has thanked: 20767 times
- Been thanked: 10453 times
That came out well considering the seeing conditions Paul!
- Has thanked: 9306 times
- Been thanked: 6140 times
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Thanks for the comments everyone.
@Brian: hope you get good results with the plugin. After using it "for real" a few times now, I think there are a few things that could it make easier to use, so I am planning to do some work on it, mostly on the plugin. That will take some time (will need a new "health" break) hopefully by end of June can get some improvements done.
Kind regards,
Paul
Kind regards,
Paul
