Another beautiful morning and another opportunity to image AR2738 with my 150mm/DS Lunt 35 mod.
Basler acA1920-155um IMX174
2.5x Powermate
AS!3
ImPPG
20190413_AR2738_Ha_Mono by Stuart Green, on Flickr
6 pane mosaic
20190413_AR2738_Ha2_Mono by Stuart Green, on Flickr
Note the small flare in the second image and the filament tendril linking it to the sunspot's penumbra. It only lasted a matter on minutes before melting away. There's also a developing light bridge.
Thanks for looking.
AR2738 in Ha April 13th 19th
- Has thanked: 8418 times
- Been thanked: 8163 times
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Re: AR2738 in Ha April 13th 19th
Beautiful results, Stu, your mod works really fine. The bridge is clearly visible.
Raf
- Has thanked: 1171 times
- Been thanked: 1360 times
- Been thanked: 4340 times
Fabulous images Stuart
Great to have something to image again
- Been thanked: 10247 times
Excellent images Stu! Glad the sun was shining for you!
- Has thanked: 9145 times
- Been thanked: 6025 times
Nice little flare and great mosaic. It shows the region of activity quite well. Thanks, Stu.
Phil
Phil
Many thanks, everyone. A bit more cloud here today. We’ll have to see if it’s clear enough for any further imaging.
