Here is an image taken on April 14. The light bridge is much reduced compared to the April 13 image. The dark filament spliting the light bridge in two is at the limit of the resolution :
Best regards
AR2738 in Ca K on April 14 with the TOA 150
- Been thanked: 2725 times
- Has thanked: 20908 times
- Been thanked: 10567 times
Re: AR2738 in Ca K on April 14 with the TOA 150
Another incredible CaK image Christian! What barlow are you using to get you up to f22?
Thanks Mark :-)
I am using the Baader Planetarium FFC. It performs beautifully in near UV.
- Has thanked: 18062 times
- Been thanked: 8918 times
Another beauty! the penumbra looks like a giant eye
- Has thanked: 2497 times
- Been thanked: 4919 times
- Has thanked: 65 times
- Been thanked: 4447 times
Outstanding image Christian...excellent capture and processing
