With all the AR activity moving off the disk I thought today's session might be quite short, turned out quite the opposite! Lots of prominence activity to grab instead.
Not a whole lot going on in white light but found some nice detail close up.
Ca-K was where all the fun was today!
Broke out the PST for a bit of H Alpha, many people will do this justice later but until then...
I feel an H Alpha upgrade coming on
The Sun - 21st April
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
David
- Has thanked: 9145 times
- Been thanked: 6027 times
- Been thanked: 4340 times
Re: The Sun - 21st April
Nicely done David...even with the limited activity you pulled in a lot of details
- Has thanked: 20442 times
- Been thanked: 10248 times
A comprehensive set of images there David ! very good.
- Been thanked: 8793 times
Very nice to see the Halpha and great to see some nice granulation in the WL too I didn't think there were any proms in Halpha today, I guess I shouldn't rely on GONG and should look on here instead
- Has thanked: 2412 times
- Been thanked: 4787 times
David
- Has thanked: 8418 times
- Been thanked: 8165 times
A very nice set there, David. Lovely CaK.
David
