9 inch Rumak: granulation and AR2738
Today I tried out the 9 inch Rumak. Optics are made by Intes: MK-91. So it is a 9 inch f/13,5 Rumak. Rebuild (not by me) in a 33cm diameter double Carbon tube. The inside of the Tube is isolated. Heavy machine: about 14kg.
But for the Cem 60 it is no real problem:
20190422_105326_resized by bart moors, on Flickr
Nice backfcocus!
20190422_105251_resized by bart moors, on Flickr
Wanted to image the granulation. Seeing was bad, so besides the Naader AstroSolar ND3.8 I had to use an Astromik Red filter. Difficult to focus without any sunspots and these conditions, but here is the result:
Sun_102036_220419_Gain=0(off)_Exposure=2ruis_PS by bart moors, on Flickr
And a goodbye to AR2738, image taken last friday with the 150mm Skywactcher achromat:
Moon_104250_190419_Gain=0(off)_Exposure=4_2 by bart moors, on Flickr
Thanks for watching! Bart.
Nice backfcocus!
- Has thanked: 20757 times
- Been thanked: 10445 times
Re: 9 inch Rumak: granulation and AR2738
Looks like you're having fun Bart! Nice images. What fl and camera with the WL shot?
Indeed Mark! Forgot to mention it: prime focus so about 3100mm. ASI290MM.marktownley wrote: ↑Mon Apr 22, 2019 2:03 pm Looks like you're having fun Bart! Nice images. What fl and camera with the WL shot?
Besides the Red filter I also used a 2 inch Beloptik UV/IR cut on kg3.
Nice configuration Bart!
- Has thanked: 9298 times
- Been thanked: 6133 times
A very nice scope and a killer granulation shot, Bart ! What etalon did you use for the Ha ?
Hi Franco, thanks!
Baader D-erf - Baader 35nm H-alpha - Baader 1,25x glasspath - PST etalon - Lunt B1200 - ASI290MM.
So a normal PST etalon.
At the moment Gerd Neuman (Astronomik) is rebuilding a filter drawer so I can doublestack my two PST etalons. In the filter drawer there goes a circular polarizer.
- Has thanked: 1 time
- Been thanked: 2725 times
Excellent first light !
A 10"ERF might be of use for this scope.
Thanks Christian. Yes, it would definitely be of use! But to fund it I would have to sell the Rumak. (-;christian viladrich wrote: ↑Mon Apr 22, 2019 5:22 pm Excellent first light !
- MAURITS
- Has thanked: 2463 times
- Been thanked: 4879 times
Great images. That's a interesting scope and a good performer.
Phil
Phil
- Been thanked: 4409 times
Hi Bart...
Awesome WL and Ha images with the scope...the granulation is extraordinary
- Has thanked: 17925 times
- Been thanked: 8895 times
Wow! the granulation is amazing! I think your bad seeing is the same as my good seeing
Thanks all!
Alexandra, since using the SSM my idea of good and bad seeing is shifting a bit. When I look at the SSM, it jumps up and down. So when the average seeing is bad, there are still a few moments when the seeing is actually pretty good. This was captured during such a moment.
Good logic Bart!
- Christopher
- Has thanked: 33 times
- Been thanked: 34 times
Bravo on the granulation shot Bart. Looks like your going to have some fun with that particular scope!
Christopher
- pedro
- Has thanked: 14 times
- Been thanked: 6686 times
Great HR images Bart. The Rumak is a great instrument
Pedro Re'
Thanks Christopher and Pedro. Looking forward to using the scope on the moon, planets and the sun. Bought it in june last year, tried it out for a couple of weeks. And then decided to change the focuser because I was not pleased with it. Put the scope upside down so I could work in a more comfortable position. Did not realise the primary was held by just the adapter plate of the focuser. So when removing the focuser the complete primary (plus baffle) dropped down. Thank god it did not hit the corrector.....Christopher wrote: ↑Tue Apr 23, 2019 5:24 pm Bravo on the granulation shot Bart. Looks like your going to have some fun with that particular scope!
In the fall I brought it to a friend I met on a Dutch forum. He also fine-tuned my Intes M703 some time ago. It took him a while, but the scope is now even better than before. He changed amongst other things the secondary holder. And collimated it perfectly. Really happy to have it back again!
