9 inch Rumak: granulation and AR2738
bart1805
Been thanked: 1 time
Post by bart1805 »
Today I tried out the 9 inch Rumak. Optics are made by Intes: MK-91. So it is a 9 inch f/13,5 Rumak. Rebuild (not by me) in a 33cm diameter double Carbon tube. The inside of the Tube is isolated. Heavy machine: about 14kg.
But for the Cem 60 it is no real problem:
Image20190422_105326_resized by bart moors, on Flickr
Nice backfcocus!
Image20190422_105251_resized by bart moors, on Flickr
Wanted to image the granulation. Seeing was bad, so besides the Naader AstroSolar ND3.8 I had to use an Astromik Red filter. Difficult to focus without any sunspots and these conditions, but here is the result:
ImageSun_102036_220419_Gain=0(off)_Exposure=2ruis_PS by bart moors, on Flickr
And a goodbye to AR2738, image taken last friday with the 150mm Skywactcher achromat:
ImageMoon_104250_190419_Gain=0(off)_Exposure=4_2 by bart moors, on Flickr
Thanks for watching! Bart.
Has thanked: 20738 times
Been thanked: 10428 times
Re: 9 inch Rumak: granulation and AR2738
Looks like you're having fun Bart! Nice images. What fl and camera with the WL shot?
bart1805
Post by bart1805 »
marktownley wrote: Mon Apr 22, 2019 2:03 pm Looks like you're having fun Bart! Nice images. What fl and camera with the WL shot?
Indeed Mark! Forgot to mention it: prime focus so about 3100mm. ASI290MM.
Besides the Red filter I also used a 2 inch Beloptik UV/IR cut on kg3.
Nice configuration Bart!
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
A very nice scope and a killer granulation shot, Bart ! What etalon did you use for the Ha ?
bart1805
Post by bart1805 »
ffellah wrote: Mon Apr 22, 2019 3:22 pm A very nice scope and a killer granulation shot, Bart ! What etalon did you use for the Ha ?
Hi Franco, thanks!
Baader D-erf - Baader 35nm H-alpha - Baader 1,25x glasspath - PST etalon - Lunt B1200 - ASI290MM.
So a normal PST etalon.
At the moment Gerd Neuman (Astronomik) is rebuilding a filter drawer so I can doublestack my two PST etalons. In the filter drawer there goes a circular polarizer.
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Excellent first light !
A 10"ERF might be of use for this scope.
bart1805
Post by bart1805 »
christian viladrich wrote: Mon Apr 22, 2019 5:22 pm Excellent first light !
Thanks Christian. Yes, it would definitely be of use! But to fund it I would have to sell the Rumak. (-;
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
WOW, what a nice granulation.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Astrophil
Been thanked: 581 times
Post by Astrophil »
Great images. That's a interesting scope and a good performer.
Phil
Has thanked: 64 times
Been thanked: 4406 times
Post by MapleRidge »
Hi Bart...
Awesome WL and Ha images with the scope...the granulation is extraordinary :bow
Has thanked: 17888 times
Been thanked: 8887 times
Wow! the granulation is amazing! I think your bad seeing is the same as my good seeing ;)
:bow
bart1805
Post by bart1805 »
Montana wrote: Tue Apr 23, 2019 11:28 am Wow! the granulation is amazing! I think your bad seeing is the same as my good seeing ;)
Thanks all!
Alexandra, since using the SSM my idea of good and bad seeing is shifting a bit. When I look at the SSM, it jumps up and down. So when the average seeing is bad, there are still a few moments when the seeing is actually pretty good. This was captured during such a moment.
Good logic Bart!
Christopher
Has thanked: 33 times
Been thanked: 34 times
Post by Christopher »
Bravo on the granulation shot Bart. Looks like your going to have some fun with that particular scope!
Christopher
pedro
Has thanked: 14 times
Been thanked: 6683 times
Post by pedro »
Great HR images Bart. The Rumak is a great instrument
bart1805
Post by bart1805 »
Christopher wrote: Tue Apr 23, 2019 5:24 pm Bravo on the granulation shot Bart. Looks like your going to have some fun with that particular scope!
Thanks Christopher and Pedro. Looking forward to using the scope on the moon, planets and the sun. Bought it in june last year, tried it out for a couple of weeks. And then decided to change the focuser because I was not pleased with it. Put the scope upside down so I could work in a more comfortable position. Did not realise the primary was held by just the adapter plate of the focuser. So when removing the focuser the complete primary (plus baffle) dropped down. Thank god it did not hit the corrector.....
In the fall I brought it to a friend I met on a Dutch forum. He also fine-tuned my Intes M703 some time ago. It took him a while, but the scope is now even better than before. He changed amongst other things the secondary holder. And collimated it perfectly. Really happy to have it back again!
