Today's Solar Features in High Res | April 29th 2019
Has thanked: 1179 times
Been thanked: 1369 times
Post by MalVeauX »
Seeing was ok this morning, but not superb. Had some clear skies so I figured even though there's no major features going on, there is always something to find with enough resolution. Went after some small prominences, spicules, convection cells and other tiny features in the photosphere & chromoshpere.
B&W:
Colored:
Equipment:
C8 Edge HD + Aires Tri-Band D-ERF
Quark Chromosphere + Baader 2" UV/IR block filter (HA)
2x Barlow + Baader 610nm Long Pass + Baader 1.8 ND (WL)
ST80 Refractor
SkyBender + Baader Blue CCD-IR Block + Chroma 393.37 0.1nm (CaK)
David_The_Bears_Fan
Has thanked: 423 times
Been thanked: 167 times
Re: Today's Solar Features in High Res | April 29th 2019
Post by David_The_Bears_Fan »
Great set Marty. Mostly clouds here at the moment but I did get a few minutes at the eyepiece of the Evostar with the Lacerta wedge earlier.
David
Kit: Skywatcher Evostar 120 on Celestron CG-4 / Bresser AR102xs / Lunt B1200 Ca-K Module / Lacerta Herschel Wedge / Daystar Combo Quark / ZWO ASI178MM & 120MC-S / QHY5-II Mono
Astrophil
Been thanked: 581 times
Post by Astrophil »
Marty, I really like the texture you brought out in the first image. Great detail and processing. Are the HR surface images (Ha and WL) the same region? They turned out well.
Phil
Has thanked: 20738 times
Been thanked: 10436 times
Looks good!
Has thanked: 17924 times
Been thanked: 8889 times
Wow!! the prominence has some beautiful detail, a tremendous set Marty :bow
Has thanked: 8523 times
Been thanked: 8253 times
Another very fine set of images, Marty. Nice!
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Excellent Marty, a lot of very clear details.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
