Solar Analemma. This outstanding image from Alexandra Hart taken over a period of 4 years charts the midday position of the sun in the sky throughout the year. The north–south component of the analemma results from the change in the Sun's declination due to the tilt of Earth's axis of rotation. The east–west component results from the nonuniform rate of change of the Sun's right ascension, governed by combined effects of Earth's axial tilt and orbital eccentricity.
Merry Christmas, Happy New Year and looking forward to a great solar cycle 25!
Solar Images taken May 9th 2019 and a question.
Martin_S
Post by Martin_S » Fri May 10, 2019 10:19 am
Yesterday was my first opportunity in over 2 weeks to get my Lunt LS60tHa out for some Imaging the clouds were rolling in fast so I had to quickly take these images.I tried some white light Imaging for the first time with my Skywatcher Evostar ED72 .5 focal reducer and ASI 120mm-s camera. I stacked 100 frames as the seeing was good at the time. I would like to do better Imaging in White light. I do have a Celestron 6SE SCT . I could use , would this scope with filters achieve better results. Thanks for looking, any suggestions would be most welcome
Martin
bart1805
Re: Solar Images taken May 9th 2019 and a question.
Post by bart1805 » Fri May 10, 2019 11:05 am
Hi Martin,
Yes, you would get better results: bigger aperture.
You would need the Baader ND3.8 Astrosolar. This is just for imaging, not visual.
You can buy a complete filter or a sheet of Astrosolar. Then you would have to make your own holder.
BTW: nice images, that 2741 is a real beauty.
CS! Bart.
Martin_S
Post by Martin_S » Fri May 10, 2019 11:24 am
Hi Bart, thank you for your reply, how much definition do you loose using a visual filter as opposed to an imaging filte?r, there is a Celetron filter at a good price on E-bay right now
Martin
bart1805
Post by bart1805 » Fri May 10, 2019 11:50 am
Can't tell you that. I suppose it is a ND5.0 filter made out of glass? Then your exposure time would be substantially longer. So more effect of the seeing.
Normally only quite expensive glass filters can compete with the advantages of Astrosolar.
Post by Montana » Fri May 10, 2019 12:53 pm
Fantastic images :hamster: :bow
As regards white light, Baader solar film is optically much better quality than any glass filter, unless the glass is very expensive indeed. I tried Baader ND5 filter on my Celestron C11 and there was not enough light to image with. The exposure times were so long it was not worth trying. I now use ND3.8 and the exposure times are fast enough to take images. Also what is a must is to use a UV/IR block filter on your camera as the out of focus light makes your WL images blurred. This makes a huge difference to focus. Also a Continuum filter helps a lot too to improve contrast.
PDB
Post by PDB » Fri May 10, 2019 1:08 pm
Hi Martin,
can confirm the ND3.8 gives much better results than the ND5. I have been using the ND5 in my C8 at prime focus and this still ok, but adding extra filters (baader continuum ...) will make exposure to slow. Also if adding any barlow to increase f/ratio will need the 3.8. (ND 3.8 is difficult to find nowadays for larger apertures, think the largest size sold now is A4 format)
Looking at the white light images think you also can get a better resolution. Did I read correctly you are using a .5 reducer on the Skywatcher? That will
give you an F/3 ratio which is WAY undersampled with the ASI120MM-S having 3.75µ pixels. Maybe a 2x or 2.5x barlow would give a better match between telescope and camera.
Paul
Martin_S
Post by Martin_S » Fri May 10, 2019 9:14 pm
Thank you Paul and Alexandra , I now have some good points to work on.
Martin
Post by marktownley » Sun May 12, 2019 3:22 pm
Nice shots!
Post by MapleRidge » Sun May 12, 2019 3:28 pm
Hi Martin...
A nice set of images!!!
Martin_S
Post by Martin_S » Tue May 14, 2019 10:14 am
Thank you , Mark and Brian
Martin_S
Post by Martin_S » Tue Jul 16, 2019 10:10 am
Thought I'd give this thread a recap, I had poor results on my first attempt at white light Imaging. This is my second attempt taken today . I used my ED72 and my ASI120mm camera at prime focus,5.0 solar film El-cheapo IR cut filter and an El-cheapo Wratten #58 green filter. Post processing AS!2 and registax.
I can actually see some surface detail. Next time I'll use some slight focal reduction to fit the full disc to the sensor.
Martin
krakatoa1883
Post by krakatoa1883 » Tue Jul 16, 2019 11:47 am
Good result, granulation is evident. With a 0.5x focal reducer you can image the full disc.
Raf
Post by Montana » Tue Jul 16, 2019 1:35 pm
An excellent second attempt :hamster:
Martin_S
Post by Martin_S » Tue Jul 16, 2019 8:59 pm
Thank you Raf and Alexandra . I bought 2 cheap filters after reading this article
http://www.schursastrophotography.com/s ... icle3.html
Martin
Post by Carbon60 » Wed Jul 17, 2019 5:36 am
Looking better there, Martin.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
