Page 1 of 1
Solar Images taken May 9th 2019 and a question.
Posted: Fri May 10, 2019 10:19 am
by Martin_S
Yesterday was my first opportunity in over 2 weeks to get my Lunt LS60tHa out for some Imaging the clouds were rolling in fast so I had to quickly take these images.I tried some white light Imaging for the first time with my Skywatcher Evostar ED72 .5 focal reducer and ASI 120mm-s camera. I stacked 100 frames as the seeing was good at the time. I would like to do better Imaging in White light. I do have a Celestron 6SE SCT . I could use , would this scope with filters achieve better results. Thanks for looking, any suggestions would be most welcome
Martin
Re: Solar Images taken May 9th 2019 and a question.
Posted: Fri May 10, 2019 11:05 am
by bart1805
Hi Martin,
Yes, you would get better results: bigger aperture.
You would need the Baader ND3.8 Astrosolar. This is just for imaging, not visual.
You can buy a complete filter or a sheet of Astrosolar. Then you would have to make your own holder.
BTW: nice images, that 2741 is a real beauty.
CS! Bart.
Posted: Fri May 10, 2019 11:24 am
by Martin_S
Hi Bart, thank you for your reply, how much definition do you loose using a visual filter as opposed to an imaging filte?r, there is a Celetron filter at a good price on E-bay right now
Martin
Posted: Fri May 10, 2019 11:50 am
by bart1805
Can't tell you that. I suppose it is a ND5.0 filter made out of glass? Then your exposure time would be substantially longer. So more effect of the seeing.
Normally only quite expensive glass filters can compete with the advantages of Astrosolar.
Posted: Fri May 10, 2019 12:53 pm
by Montana
Fantastic images :hamster: :bow
As regards white light, Baader solar film is optically much better quality than any glass filter, unless the glass is very expensive indeed. I tried Baader ND5 filter on my Celestron C11 and there was not enough light to image with. The exposure times were so long it was not worth trying. I now use ND3.8 and the exposure times are fast enough to take images. Also what is a must is to use a UV/IR block filter on your camera as the out of focus light makes your WL images blurred. This makes a huge difference to focus. Also a Continuum filter helps a lot too to improve contrast.
Posted: Fri May 10, 2019 1:08 pm
by PDB
Hi Martin,
can confirm the ND3.8 gives much better results than the ND5. I have been using the ND5 in my C8 at prime focus and this still ok, but adding extra filters (baader continuum ...) will make exposure to slow. Also if adding any barlow to increase f/ratio will need the 3.8. (ND 3.8 is difficult to find nowadays for larger apertures, think the largest size sold now is A4 format)
Looking at the white light images think you also can get a better resolution. Did I read correctly you are using a .5 reducer on the Skywatcher? That will
give you an F/3 ratio which is WAY undersampled with the ASI120MM-S having 3.75ยต pixels. Maybe a 2x or 2.5x barlow would give a better match between telescope and camera.
Posted: Fri May 10, 2019 9:14 pm
by Martin_S
Thank you Paul and Alexandra , I now have some good points to work on.
Martin
Posted: Sun May 12, 2019 3:22 pm
by marktownley
Nice shots!
Posted: Sun May 12, 2019 3:28 pm
by MapleRidge
Hi Martin...
A nice set of images!!!
Posted: Tue May 14, 2019 10:14 am
by Martin_S
Thank you , Mark and Brian
Posted: Tue Jul 16, 2019 10:10 am
by Martin_S
Thought I'd give this thread a recap, I had poor results on my first attempt at white light Imaging. This is my second attempt taken today . I used my ED72 and my ASI120mm camera at prime focus,5.0 solar film El-cheapo IR cut filter and an El-cheapo Wratten #58 green filter. Post processing AS!2 and registax.
I can actually see some surface detail. Next time I'll use some slight focal reduction to fit the full disc to the sensor.
Martin
Posted: Tue Jul 16, 2019 11:47 am
by krakatoa1883
Good result, granulation is evident. With a 0.5x focal reducer you can image the full disc.
Posted: Tue Jul 16, 2019 1:35 pm
by Montana
An excellent second attempt :hamster:
Posted: Tue Jul 16, 2019 8:59 pm
by Martin_S
Thank you Raf and Alexandra . I bought 2 cheap filters after reading this article
http://www.schursastrophotography.com/s ... icle3.html
Martin
Posted: Wed Jul 17, 2019 5:36 am
by Carbon60
Looking better there, Martin.
