May 10th Spots
May 10th Spots
Hi All,
A nice day for solar imaging, only a few clouds and a light breeze. The Quantum Six was the scope of choice today. First off are portraits of the active regions then a group shot. Finally, not to the waste time while the etalon heated up, AR12741 without it's chromosphere cover.
Phil
Phil
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Re: May 10th Spots
Great shots.
David
- Been thanked: 2725 times
Re: May 10th Spots
Beautifull images and processing !
- Has thanked: 1188 times
- Been thanked: 1382 times
- Has thanked: 9307 times
- Been thanked: 6144 times
Re: May 10th Spots
These are INCREDIBLE, Phil ! Perfect conditions, capture and processing...and great gear
Re: May 10th Spots
Thanks for the nice comments.
Oops, I mislabeled the images. They were taken with a Quantum Six telescope not an Questar. There is no Questar 6.
Phil
Phil
- Has thanked: 17970 times
- Been thanked: 8905 times
Re: May 10th Spots
Absolutely superb in every way, very sharp and crisp and yet beautifully smooth
Re: May 10th Spots
Thank you Alexandra, I have been trying to follow your suggestions. Now if I could narrow the bandwidth of the filter they would be better.
Phil
Phil
- Christopher
- Has thanked: 33 times
- Been thanked: 34 times
Re: May 10th Spots
I love that scope Phil! Beautiful work.
Christopher
- Been thanked: 4422 times
Re: May 10th Spots
Lovely images Phil...well done
- Has thanked: 20783 times
- Been thanked: 10462 times
Re: May 10th Spots
Top shots! Lots of detail there.
