Heya,
Had some ok seeing this morning and was able to tinker around in various wavelengths to test things out. The little plage is still present near the limb, but it's activity seems to have already gone down a bit and the large proms from yesterday are gone, but a small bright prom is on the other limb that is interesting.
B&W:
Colored:
C8 Edge + Aires D-ERF
ST80
Quark 656nm Filter
E.O. 430nm Filter
PST CaK 393nm Filter
ASI290MM
Plage, Prom, Discs | HA, GB, CAK | May 26th 2019
- Has thanked: 1188 times
- Been thanked: 1382 times
Re: Plage, Prom, Discs | HA, GB, CAK | May 26th 2019
Great Marty, are there images taken with the ASI 290MM.
Hi Maurits, yessir, all where done with the ASI290MM except for the Plage in HA, that was the 174MM. The rest, convection cells, discs, etc, were with the 290MM. I've been experimenting with using the smaller sensor to have more options for image scale using smaller pixels.
- Been thanked: 4971 times
Marty:
Beautiful session.
¿How many fps are you getting from your ASI290?
Beautiful session.
Hi Eric,
In FireCapture with a Flat Calibration frame and Gamma checked and being used, it is around 75fps at full resolution. It's much faster if I turn off the flat calibration & gamma use.
I have never been able to get the full advertised fps from my IMX174 nor the 290MM with my setup. I'm using a fast SSD (Samsung EVO) that is 1TB and I've tried a few different connections to the USB3 port, but generally I seem to top out around 100~110 FPS with both cameras in FireCapture with no overlay flat frame or gamma use. Not sure if the RAM is the limit or if my serial bus is the limit or what.
- Has thanked: 17970 times
- Been thanked: 8905 times
Excellent pictures I really like the granulation, is that WL?
Yes, it was 430nm with a 200mm aperture
- Has thanked: 20783 times
- Been thanked: 10464 times
These came out well! I'm tempted to get a 290M myself.
