June 1st images
Astrophil
Been thanked: 581 times
June 1st images
Post by Astrophil »
I hadn't planned to image today but a quick glance at GONG showed a nice looking surge prom developing so out I went. This was about 14:50 UT. By the time everything was setup and the etalon was up to temperature the show was over. I missed it. Maybe next time.
I did capture a region of disturbance and a prom for my efforts.
Has thanked: 8523 times
Been thanked: 8252 times
Re: June 1st images
Post by Carbon60 »
That’s the way it goes sometimes, Phil. Usually it’s weather related.....just get set up and the clouds roll in to spoil the show.
Great images. Lots of lovely fine structures in that prom shot.
Been thanked: 4957 times
Re: June 1st images
Post by eroel »
Phil:
You got beautiful details even with bad weather.
robert
Has thanked: 4 times
Been thanked: 1275 times
Re: June 1st images
Post by robert »
Very fine prom detail, great
Robert
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Re: June 1st images
Post by MAURITS »
Very nice captured details Phil.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 9280 times
Been thanked: 6127 times
Re: June 1st images
Post by ffellah »
That prom image is fantastic, Phil !
Has thanked: 64 times
Been thanked: 4407 times
Re: June 1st images
Post by MapleRidge »
Nicely detailed image Phil :bow
Astrophil
Re: June 1st images
Post by Astrophil »
As always, thanks for the kind remarks. Definitely helps during the slow Solar season.
Has thanked: 156 times
Been thanked: 893 times
Re: June 1st images
Post by Valery »
Excellent resolution at the edge. Fantastic spiculaes.
I see your etalon was somewhat off-band. Spiculaes better seen when an etalon is somewhat red shifted.
BTW. The seeing often is good just before clounds are rolled on.
Astrophil
Re: June 1st images
Post by Astrophil »
Valery, you are absolutely correct. I did set the etalon temperature approximately 1.5°C hotter (red) that normal.
Has thanked: 1179 times
Been thanked: 1369 times
Re: June 1st images
Post by MalVeauX »
Lovely captures Phil!
Been thanked: 10432 times
Re: June 1st images
These are nice images Phil!
Has thanked: 17901 times
Been thanked: 8888 times
Re: June 1st images
Lovely! the top image is like beautiful fur :bow
yltansg
Has thanked: 1455 times
Been thanked: 1444 times
Re: June 1st images
Post by yltansg »
Hi Phil,
Lovely images. What is your setup like?
Alfred
Astrophil
Re: June 1st images
Post by Astrophil »
Hi Alfred,
Here is a pic of the setup. These images were taken without the Daystar Combo. It was replaced with an extension tube.
viewtopic.php?f=4&t=25497
yltansg
Re: June 1st images
Post by yltansg »
Nice setup. Thanks, Phil.
Alfred
