Hi:
Raining season has started at my place, so I had to image through haze, passing clouds and wind, so the shots are not optimal.
Thanks for looking, the images were taken at the home observatory, through a Solarmax 90-DS, a 102mm f/9 Meade refractor with a CaK PSTmod, and with a 102mm f/7 Stellarvue working at f/28 with an old Daystar T-scanner filter. The camera was the SKYnyx 2-2. (The last 3 look better in another window)
Best regards to all,
Sol from the 1st of June 2019.
- Been thanked: 4980 times
- Been thanked: 4427 times
Re: Sol from the 1st of June 2019.
Excellent full disk images Eric, well done
Wow! Another great set of images. It doesn't seem to matter which telescope you use or what the weather throws at you. Nicely done, Eric.
Phil
Phil
- Been thanked: 10489 times
An excellent selection of disks and closeups Eric!
Lots of stunning detail there Eric, you never fail to deliver first class pics whatever the weather
- Has thanked: 1188 times
- Been thanked: 1382 times
- Has thanked: 8559 times
- Been thanked: 8290 times
Excellent, Eric. Another very fine set.
- Has thanked: 9319 times
- Been thanked: 6157 times
Very sharp, excellent results, Eric. The prominences came up very detailed.
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
