With seeing going from bad to worse, I recorded 10 files and culled the following from the bunch.I used a setup I had used only once before with a 0.63 reducer right outside the scope. I know that this presents the telecentric with a less than ideal f/6.3 beam, it seems to work.
Lou
Around the sun's edge on August 5
- Been thanked: 1735 times
- Been thanked: 4419 times
Re: Around the sun's edge on August 5
Hi Lou...
Good set of images despite the conditions. The long focal lengths need a lot of patience to get usable results (at least in this part of the world)
- Has thanked: 20778 times
- Been thanked: 10456 times
They came out well Lou
- Has thanked: 17970 times
- Been thanked: 8904 times
You really do find the smallest prominences, well done, these are great
