Solar FDs in 540 nm Continuum and CaK
- Has thanked: 8415 times
- Been thanked: 8161 times
The sky only cleared after lunch. With the late start and a brisk wind I thought it only worth setting up for FD views. No close-ups
First off 'WL' with a Baader solar continuum filter (540 nm) on the nose of a Lacerta wedge on my 72mm f6 Altair Astro 'Lightwave' ED refractor.
20190817_WL_Mono by Stuart Green, on Flickr
and in colour.
20190817_WL_Colour by Stuart Green, on Flickr
And then over to CaK with the same scope and a Lunt B600 CaK module with an omega filter and Baader K-line.
20190817_CaK_FD_Mono by Stuart Green, on Flickr
_20190817_CaK_FD_Colour by Stuart Green, on Flickr
It's just a pity things are so quiet currently.
Thanks for looking.
and in colour.
Thanks for looking.
- Has thanked: 20435 times
- Been thanked: 10245 times
Re: Solar FDs in 540 nm Continuum and CaK
Nice views Stu. It was blustery this afternoon, scope was bouncing all over the place. The sun is quiet though unfortunately. Look hard in the WL though, the polar faculae are visible, they were prominent today.
- Has thanked: 9144 times
- Been thanked: 6025 times
A nice set, Stu. I like the CaK, it came out really well.
- Been thanked: 4786 times
- Has thanked: 17667 times
- Been thanked: 8789 times
Beautiful full discs Stuart
The Sun came out for me too in the afternoon but the wind made everything a challenge, you have much crispier shots than me.
- Been thanked: 4904 times
Stu:
Beautiful FD´s, even the featureless WL ones.
Many thanks, everyone. Much appreciated. It’s a pity there isn’t more to see.
I see what you mean, Mark, now you’ve pointed them out.marktownley wrote: ↑Sat Aug 17, 2019 7:42 pm ........Look hard in the WL though, the polar faculae are visible, they were prominent today.
- Has thanked: 714 times
- Been thanked: 496 times
The Lacerta Wedge is a very fine instrument.
Your CaK pic is beautifull.
What is you setup? You removed the 2 front filters of the Lunt and replaced them with an omega filter and a K-line?
In which order? K-Line first then Omega?
CS
Alex
CS
Alex
- Been thanked: 4340 times
These are fine FD image Stu, and the CaK version is very sharp. Well done
Many thanks, Alex/Brian.
Hi Alex,
No modification to the Lunt necessary. The filters are simply screwed on the front of the Barlow. The sequence is as follows:
Objective, Lunt, Baader K-line, Omega, 1.5x Barlow, camera.
Hope this helps.
