Still trying to improve my setup.
Here a Solar Newton in KLine.
CS
Alex
2019-Aug-21
Solar Netwon T300
F1800 F/D6
Powermate x5
Baader KLine 396nm, ~8nm FWHM
ASI174
T300 Granuation from St Veran
Re: T300 Granuation from St Veran
That looks (even on a phone) amazing! Did you try Christian's Basler with your set up to see if the difference between the 300mm pictures has something to do with the camera?
- pedro
- Has thanked: 14 times
- Been thanked: 6578 times
Great HR image Alex
Pedro Re'
- Been thanked: 8794 times
- Has thanked: 9148 times
- Been thanked: 6027 times
- Been thanked: 4787 times
- Has thanked: 714 times
- Been thanked: 496 times
Thank you for the nice comments.
Christian's scope is operational since several years and very stiff: carbon, etc.
I'm still in the experiment phase with my my scope; the secondary holder is a cheapo for now, not very rigid.
We discussed with Christian the camera quality. The Basler should be more sophisticated in terms of internal electronic; at least the basler has the gamma conversion made by the camera electronic, which is not the case of the ASI (Software gamma).
But we are not using gamma. We didn't neither compare both cameras.
Christian is also using a different gain.
CS
Alex
CS
Alex
- Been thanked: 4340 times
Excellent resolution Alex
- Been thanked: 10248 times
Very impressive indeed!
