The Internet is back at St Véran ..
Here is a set of pictures taken on August 21 with the 300 mm Newtonian and the 396-5 nm filter.
Let's start with a region close to the Eastern limb, with many faculae and darker areas.
The N-W limb with granulation visible to the limb.
A little bit farther from the limb, with faculae still visible.
An area close to the center of the disk with a ring of filigrees in the center of the image.
Another areas with darker diffuse areas :
Best regards
HR images taken with the N300 on August 21
- Been thanked: 2725 times
- Has thanked: 9387 times
- Been thanked: 6201 times
Re: HR images taken with the N300 on August 21
An amazing set of images, Christian, but the fourth one is truly spectacular. The resolution and contrast are magnificent.
Superb set of images, fascinating to see, thanks for sharing
Michael Buxton
Ocean Beach, California
- Has thanked: 65 times
- Been thanked: 4462 times
Outstanding resolution Christian
- Has thanked: 141 times
- Been thanked: 240 times
Amazing
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
- Has thanked: 20962 times
- Been thanked: 10593 times
Superb! Lots to see on these images.
- Has thanked: 18105 times
- Been thanked: 8942 times
Absolutely incredible, but the fourth is also my favourite
- Has thanked: 2501 times
- Been thanked: 4928 times
Thanks to all :-)
I like the fourth one too !
