Saturday Sun Aug 24th
- Has thanked: 8418 times
- Been thanked: 8163 times
A blue sky day, but stubborn cirrocumulus clouds right over the Sun this morning frustrated any attempts at long-term imaging (animations), but I was determined to at least get some images the lovely proms that I could see on GONG and occasional gaps gave me some short periods of cloud-free viewing. First off, though, was a quick experiment with a blue 430 nm filter fitted to my Lacerta WL wedge. Removing the neutral density filter gave me a bright image (as you'd expect), which I was hoping for and which I could control using a polarising filter fitted to the nose of my 5x Powermate. The objective was to achieve as fast an exposure time as possible to freeze out the atmospheric turbulence without frying my IMX174 sensor!! Rotating the Powemate/polariser gave a brighter and dimmer image within the range I was interested in, taking the exposure time down to 122us on a 2.5x Powermate and 1ms on the x5. I could probably fine tune this a bit further to optimise. I also had a Baader IR/UV filter screwed into the nose of the Lacerta.
Here's the resulting image after processing:
20190824_430nm_x5_Lacerta by Stuart Green, on Flickr
I then reverted back to a 540 nm Green continuum, again without the neutral density filter, and this time I used a polariser double stack to attenuate the image brightness (it was too bright and out of range without crossing the polarisers). The exposure time was now down to 400us on a x5 Powermate.
20190824_540nm_x5_Lacerta by Stuart Green, on Flickr
With the sky conditions being somewhat variable it was difficult to undertake a proper side-by-side comparison, but I've tried to pull out the best level of detail using each method, so the processing is slightly different in either case. The reasoning behind all of this was really just to work out how to use the wedge with different filter configurations.
Anyhow, back to the proms....
Here's the one that Mark T imaged as a superb animation with the plasma knots.
20190824_Ha_Prom1 by Stuart Green, on Flickr
and the one diametrically opposite....
20190824_Ha_Prom2 by Stuart Green, on Flickr
Finishing off the Ha session with a general view of a patch of chromosphere.
20190824_Ha by Stuart Green, on Flickr
and back to the 430 nm for a full disk view.
20190824_WL_FD_430nm by Stuart Green, on Flickr
It took me 2.5 hrs to get this little collection together. I spent most of my time twiddling my thumbs, waiting for the gaps
Thanks for looking.
Thanks for looking.
- Has thanked: 1171 times
- Been thanked: 1360 times
- Has thanked: 17672 times
- Been thanked: 8792 times
Re: Saturday Sun Aug 24th
Oh dear, sounds like your weather was bad up north we have had clear blue skies all day some super images though and worth the patience, the prom looks fantastic I hope it sticks around till tomorrow
- Has thanked: 141 times
- Been thanked: 240 times
I'm getting tires of my jaw dropping open. If I don't compliment someone's work forgive me. Everyone is doing amazing work and I can't wait until solar max if it is this good now.
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
- MAURITS
- Has thanked: 2412 times
- Been thanked: 4787 times
Many thanks everyone.
- Has thanked: 20442 times
- Been thanked: 10247 times
A really nice set there Stu! The increase at resolution at 430nm is quite noticeable. The other images came out well too. Hope you get a bit more sun today, looks like it will clear up for you.
- Been thanked: 4340 times
Superb images across all the filters Stuart...well done
- Has thanked: 9145 times
- Been thanked: 6025 times
Great work there, Stu. The granulation shots came out really well, and the prominences are beautiful. Definitely 2.5 hours well spent.
- Been thanked: 4904 times
Stu:
A nice Saturday session, mine was hazy and cloudy.
- Has thanked: 714 times
- Been thanked: 496 times
"I also had a Baader IR/UV filter screwed into the nose of the Lacerta."
These polarized filters don't cut the IR, so using a UV/IR is a good idea.
"exposure time down to 122us on a 2.5x Powermate and 1ms on the x5".
Probably the powermate x5 has a factor of x6.5 or f7.
Great shots.
CS
Alex
Great shots.
CS
Alex
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Many thanks, everyone.
