H-alpha 31 august, 7 inch Intes, reflections and a BF30.
The good thing about a slow sun is that it is a good time for experiments! Doublestacking two PST etalons behind the 7 inch Intes went reasonably well, but there still were a lot of reflections. The Circular Polarizer does the job it is supposed to do: not a lot more reflections than when using just one PST etalon. So back to square 1. Single stack and what can I do against the reflections. Tried a lot of combinations but here is what worked best:
Baader D-Erf
Intes M703
1,25 inch Baader 35nm
PST etalon
2 inch Beloptik UV/IR cut on KG3
Lunt B1200, blue glass removed.
The biggest difference was changing the 2 inch Baader 35nm for a 1,25 inch, mounted just before the etalon. Here is the image, 2% out of 5.000 images, exposure time was 2ms. Camera used was the ASI290MM. Autostakkert, IMPPG and PS helped a lot.
11_32_28_l3_ap2577_imppg2PS_defzw by bart moors, on Flickr
About the circular polarizer between the two PST etalons:
Mounting it backwards gives a tiny bit amount more transmission. Changing the orientation of the CP seems to have no effect.
And I got the BF30 working: viewtopic.php?f=4&t=25332&hilit=bf30. It really needs the Beloptic UV/IR cut on KG3 and the B+W Redfilter 630(091) 48 mm MRC F-Pro. Tilting the BF is easy and you can clearly see the image go from a blurry mess to really clear. Transmission is really low, had to use an exposure time of about 20ms to get an image I could compare with the image posted above.
CS! Bart.
Baader D-Erf
Intes M703
PST etalon
CS! Bart.
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Re: H-alpha 31 august, 7 inch Intes, reflections and a BF30.
This is a fantastic image Bart, glad you got the BF30 working
Pedro Re'
Thanks Pedro! Yes I am glad it works. But the transmission is really low compared to the Lunt BF1200. So have to think about it if it is worth to experiment more. And how to make good use of it.
Bart, that's a great image and interesting experiment. I look forward to your final determination and results.
Good luck,
Phil
Good luck,
Phil
- Has thanked: 8418 times
- Been thanked: 8162 times
Hi Bart,
I assume the D-ERF is tilted a little bit to reduce the reflections from this surface? Similarly with the Baader 35nm? Actually, can the Baader filter be fitted on the camera nose-piece instead? I add a 656nm/7nm FWHM filter (to boost contrast) on my optical train (250mm RCT), but I place the filter at the camera.
Just a thought.
Just a thought.
Thanks Pepe and Phil!Carbon60 wrote: ↑Sun Sep 01, 2019 11:48 am I assume the D-ERF is tilted a little bit to reduce the reflections from this surface? Similarly with the Baader 35nm? Actually, can the Baader filter be fitted on the camera nose-piece instead? I add a 656nm/7nm FWHM filter (to boost contrast) on my optical train (250mm RCT), but I place the filter at the camera.
Stu, I originally used a 2 inch 35nm filter to protect the etalon. Even with the D-Erf it is stil getting quite warm at minus 200mm. So yes, the filter can be mounted on the nosepiece of the camera, but I want to be careful with the etalons.
I suspect that the 2 inch filter reflects more of the light back to the corrector than the 1,25 inch does. The D-Erf is tilted a bit, at the moment the 35nm (and the Beloptik filter) are not tilted, have to put in on the "to do" list.
I suspect the contrast wil be a bit better when I can use the full 7 inch of the Intes. The D-erf is 160 mm, so the linear obstruction is bigger than when I would use a 180 mm.
- Has thanked: 9144 times
- Been thanked: 6025 times
A great image, Bart, well done !
- Been thanked: 4786 times
- Has thanked: 20435 times
- Been thanked: 10245 times
Its a great outcome Bart!
- Been thanked: 4340 times
Superb image Bart, and I appreciate the discussion on the ERF/in line Ha filter options too
Thanks guys! Really curious about the outcome when using a full aperture Erf. Think I have to bite that bullit.
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Beautiful capture, Bart. The Proms look great on the fine disk details.
Alfred
Alfred
- Been thanked: 2713 times
Hello Bart,
This is a quite good image. Getting rid of these reflections is quite tricky. Keep us posted !
Christian
Christian
Thanks Christian (and Alfred).christian viladrich wrote: ↑Sun Sep 15, 2019 2:12 pm Hello Bart,
Christian
The season is almost over here. Hope to start next season with an Aries 8 inch Triband Erf, to be used with the Intes 703 and the 8 inch f/8 Newton for which I will start making the mirror next month.
- Been thanked: 4904 times
Bart:
Beautiful result.
Thanks for sharing your experiments.
Beautiful result.
