A small flare on a quiet sun. 280mm scope
Hello all,
Here is image of a hot plasma in a small solar flare in a spotless small active area (AR).
Equipment used: ARIES full size front mounted dielectric energy rejection filter (DERF) + second hand C11 280mm F/10 standard SCT + PST etalon + PST 5mm Blcoking filter + PGR Flea3 ICX445 b/w camera.
To see the image in a full resolution, right click on it and choose to open in a different window.
- C11 280mm ARIES 295mm DERF.jpg (288.5 KiB) Viewed 1734 times
- Has thanked: 20834 times
- Been thanked: 10502 times
Re: A small flare on a quiet sun. 280mm scope
Very fiery! very nice!
- Been thanked: 8907 times
Superb as always Valery what date was this from?
- Has thanked: 2464 times
- Been thanked: 4881 times
This is really beautiful Valery, unbelievable beautiful.
- Been thanked: 4434 times
That is an excellent image Valery...well done
- Has thanked: 17863 times
- Been thanked: 17007 times
Valery,
Absolutely stunning! Incredible sub arc second resolution. This rivals many professional images I have seen.
- Has thanked: 8559 times
- Been thanked: 8297 times
As expected from you, Valery, a really excellent image there.
Congratulations on a well deserved SPOD.
- Been thanked: 1735 times
I always look forward to your work, Valery. This is a very fine image.
A question: Is the small size of the blocking filter an important part of your technique. If I reduce the size of my blocking filter with similar optics and camera sensor, would the image improve (assuming seeing is good). Thanks.
Lou
Lou
No Lou,gabrieli wrote: ↑Sat Sep 28, 2019 9:53 am I always look forward to your work, Valery. This is a very fine image.
Lou
Larger BFs are better. The goal was to show to peoples that even such an inexpensive ultranarrowband equipment as the innards of a PST telescope is absolutely sufficient for obtaining such results in solar high resolution imaging.
And at the cost of a small dedicated solar telescope one can obtain the possibility to image the sun with contrast and resolution which greatly surpass the abilities of these dedicated solar telescopes.
- Has thanked: 141 times
- Been thanked: 240 times
Val, you stay quiet like the sun them BAM send out a photo like this.
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
- Has thanked: 9327 times
- Been thanked: 6163 times
- krakatoa1883
- Has thanked: 153 times
Great detail and very nice colouring, really impressive.
- Been thanked: 4981 times
Valery:
Superb and spectacular shot, a well deserved SPOD.
Best regards.
Best regards.
