Anybody going to catch the Mercury Transit?
- Has thanked: 141 times
- Been thanked: 240 times
I believe I will have a 10 minute and a 5 minute window to catch the transit when the local trees will not be in the way. The five minute window will be as Mercury touches the limb so maybe I will get a prom as well!
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
Aeries D-ERF
12nm Filter
- Has thanked: 1200 times
- Been thanked: 1390 times
- Has thanked: 20962 times
- Been thanked: 10593 times
Re: Anybody going to catch the Mercury Transit?
Incredibly unlikely...
- robert
- Has thanked: 4 times
- Been thanked: 1287 times
might see some clouds but I am hoping!
- Has thanked: 18105 times
- Been thanked: 8942 times
I am going to do some solar outreach at work (the car park has a view of the Sun unlike at home ) however, that almost certainly means it will be cloudy or wet.
- Has thanked: 9387 times
- Been thanked: 6201 times
It looks like it is going to be cloudy on Monday Jack, but you never know...
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Looks like I'll be clouded out unfortunately.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
They give us a good chances to catch Mercury - first and second contacts and some time of the transit begin.
The colser to the transit the better they adjust their forecast.
I will use my 150mm refractor stopped to 111mm with a Quark Combo at F/27 and Basler 1920-155 camera.
I’m forecasted for sun. I will use 152mm stopped to 95mm and quark.
Aeries D-ERF
12nm Filter
Aeries D-ERF
12nm Filter
- Has thanked: 65 times
- Been thanked: 4462 times
I plan to observe/image if the weather is cooperative...one forecast is cloud/rain the other is mostly sunny. I can already guess which one will prevail
- Has thanked: 8596 times
- Been thanked: 8325 times
I’m hoping for the best, but expecting the worst. Reports are not looking promising. I’m planning to be mobile to chase the better weather, but even then I doubt I’ll be successful.
Good luck everyone.
Good luck everyone.
I have to laugh...I have been testing the timing of the event with my landscape...this led me to trimming some 20’ high vegetation on top of a very tall ladder. When I got back down after an hour of work I realized all I did was clear the telescope path to see the blocking palm trees on the neighbor property!!
Ah well, I still have two small windows and clear skies projected. And a prayer that I get to see mercury and a prom juxtaposed.
Aeries D-ERF
12nm Filter
Aeries D-ERF
12nm Filter
- Has thanked: 17960 times
- Been thanked: 17110 times
I plan to watch it. Weather permitting. I'll be observing the event from Rock Hill SC with a friend. He will have his Takahashi FS 102 set up for white light viewing. I wish he had a DayStar Quark for it.
- Has thanked: 175 times
- Been thanked: 429 times
I too am hoping for clear skies. I may go small just because of the low chance and don't want to break a big scope down in the rain.
Some of you probably saw this on CN, but here is fun thing to do on timing. See how much sooner Mercury hits the Sun (or later it leaves) due to seeing the chromosphere. It seemed to me that the May 7, 2003 Mercury transit ended up to one minute later than expected for the photosphere because it was somewhat of a graze.
I calculated what transits we have that hit the chromosphere but miss the photosphere and therefore are not recorded as transits. It ended up in Sky and Telescope in 2003 with the calculations. The next Venus transit is June 3, 2020 when Venus is 38% of a solar diameter away from the photosphere. We would need a gigantic prominence to catch that one. Mercury had one November 17, 2012, but I forgot to look. It was 25% of a solar diameter away, so that one was very unlikely also. November 16, 2045 is a potential good one, with Mercury 6% of a solar diameter away. That one could very well be seen, although likely not by me.
Then there are the more common coronal transits, which I think may still visible from the satellite archives. We can watch the Venus 2020 one.
- Been thanked: 5016 times
Hi:
Planning to go to the rural observatory this weekend and if clear, will stay until Monday morning to get the transit.
Still having clouds and rain over the region, so I hope I have the luck to see it.
Best wishes to all,
Best wishes to all,
- Stardust5858
[img]
I've just cleaned my lunts second stack erf and the single stack objective. There was a few dust particles that I could see on each. Left the etalons well alone, lol. Anyway if it's clear is there any way of picking up Mercury just b4 it transits the disk? Would increased exposure on camera settings work as per imaging proms?10ft x 6ft Solar RoR with Warm Room
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Fortunately if the weather fails I have the NSO GONG network and NASA SDO to fall back on for an excellent, if not quite as personal a view. And of course all you guys and gals who weather permitting post excellent images and descriptions!
The wonders of the internet.
- pedro
- Has thanked: 14 times
- Been thanked: 6753 times
If the weather permits I will observe the transit from my observatories, fingers crossed
Pedro Re'
StarDust,
I don’t know how to pick up a pre transit mercury.
I may have figured a way to pick up another ten minutes on my second time window...if I throw a rope with a grappling hook to a branch 50’ up and can bend it out of the way, I might extend my time.
The things we do!
The things we do!
Aeries D-ERF
12nm Filter
Aeries D-ERF
12nm Filter
- Stardust5858
Go for it Starry Jack, nothing ventured nothing gained, lol.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Hi!
Snow is forecasted here in Norway on Monday. But I will keep an eye on the clouds. One never knows
Good luck to everybody!
Øivind Tangen
60N10E
Øivind Tangen
60N10E
I will post what I have done tomorrow. I have ropes on tree branches pulling them down, the roof of the observatory off, bushes trimmed,,,all for a few more minutes.
Aeries D-ERF
12nm Filter
Aeries D-ERF
12nm Filter
Hi Jack...
Good luck with the event considering the extra work needed to squeeze a few ore minutes out of it!
Cloud and snow in the forecast now...I don't think I can fix this with ropes
