Mercury Transit November 2019
- Has thanked: 8418 times
- Been thanked: 8163 times
I took a holiday from work today for the transit and then a 250 mile round trip to catch some half decent weather in the Midlands (UK); certainly it was a lot better than my local weather at home, which was under cloud and rain. Even so, the conditions were less than ideal with significant haze and lots of passing grey clouds. Given the changeable conditions, I reduced my SER files to 5 seconds to in order to snaffle the quickly passing best bits. Within less than 1/2 hour the session was over when the sky went really grey, forcing me to pack up before the rain started.
Equipment:
TecnoSky 125mm stopped to 110mm
1) Native FL
2) 2.5x Powermate
3) 5x Powermate
Basler acA1920-155um
Lunt B1800 Ca II K module
Processsing:
AS!3
ImPPG
PixInsight
I missed 'first contact' because of the clouds, but started capturing images at 12:39:15, about 4 minutes in, first at the native focal length of the scope (975mm) then progressively with the x2.5 and x5 powermates.
Here's the sequence.
20191111_Mercury_Mono_Native by Stuart Green, on Flickr
20191111_Mercury_Colour_Native by Stuart Green, on Flickr
20191111_Mercury_Mono_x2.5 by Stuart Green, on Flickr
20191111_Mercury_Colour_x2.5 by Stuart Green, on Flickr
20191111_Mercury_Mono_x5 by Stuart Green, on Flickr
20191111_Mercury_Colour_x5 by Stuart Green, on Flickr
After days of checking the weather reports deciding where to set up (with the reports changing by the hour!) and with such a short window of opportunity, as it turned out, I was amazed I managed to capture anything at all.
Thanks for looking.
Equipment:
1) Native FL
2) 2.5x Powermate
3) 5x Powermate
Processsing:
AS!3
ImPPG
PixInsight
Thanks for looking.
- Been thanked: 8791 times
Re: Mercury Transit November 2019
WOWWWW!! the close ups are amazing!!! well done Stuart
You should hear my story
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Great images Stu, you had good seeing
Pedro Re'
- Has thanked: 9145 times
- Been thanked: 6025 times
Great shots, Stu ! Nicely done. We had better weather than I thought here: I will post later on as I am still at work at the moment.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Great images Stu, well done.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Many thanks everyone.
Here's a very short animation before the weather turned.
20191111_Mercury_Sequence by Stuart Green, on Flickr
- Been thanked: 4340 times
Hi Pedro...
Very sharp images of the transit
Too bad the weather didn't hold up, but at least you caught the start with good images!!!
- Been thanked: 16694 times
BIG thumbs up Stewart!! Perfect sharp round disc!
JP
JP
- Been thanked: 4787 times
I must say Stuart, I really do love the CaK granulation in your close up Mercury shots, I forgot to say that before as I had Mercury on the brain
Glad to hear that you had success after driving so far for it. Wonderful contrast in your images.
Øivind Tangen
60N10E
Øivind Tangen
60N10E
- Been thanked: 10246 times
Great set of images there Stu, perseverance paid off in the end...
- Been thanked: 4904 times
Stu:
Beautifully clean shots and animation, looks like you had a good time.
Eric,
Eric,
- Has thanked: 1171 times
- Been thanked: 1360 times
Comments are always very much appreciated.
- Has thanked: 9413 times
- Been thanked: 5578 times
Absolutely Stunning Close Up images
A fine set of images, Stu. That's the first CaK transit I've seen, thanks.
Phil
Phil
Many thanks, Rainer & Phil.
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
Hi Stu - I have not seen too many transit images - thanks! I saw a Mercury transit many years ago & was surprised (I was very inexperienced) how tiny it was on the Solar disc. Your image brought back very fond memories.
