Nov. 19 Disk and AR
Astrophil
Been thanked: 581 times
Nov. 19 Disk and AR
Post by Astrophil »
A nice solar show today. Some proms and AR 2752 is still active although less energetic than yesterday. Both images were taken using the LS80 DS and PGR Grasshopper cameras. A 5x Powermate was used for the close up shot.
Phil
Has thanked: 17813 times
Been thanked: 16952 times
Re: Nov. 19 Disk and AR
Post by DeepSolar64 »
Very nice Phil! Your images show considerably more than I could pick up visually today. I could not see the AR at all.
Has thanked: 20750 times
Been thanked: 10440 times
Great images, nicely tuned double stack system!
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Nice to see some activity, Phil. Lovely FD.
MAURITS
Has thanked: 2463 times
Been thanked: 4878 times
Post by MAURITS »
Great images Phil.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 17925 times
Been thanked: 8894 times
Really beautiful work Phil, a pleasure to view :hamster: :bow
Has thanked: 9296 times
Been thanked: 6130 times
Post by ffellah »
Excellent results, Phil. The disk very evenly illuminated.
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Excellent images, Phil.
Thanks for sharing.
Astrophil
Post by Astrophil »
Thank you all for the kind comments. They definitely boost enthusiasm and motivation this time of year and when solar activity is low. James, sometimes the camera can be adjusted to see more than I can. Processing helps as well. Mark, I reset the pressure on the etalons and must have gotten lucky with the tuning. Honestly, I still have trouble finding the center wavelength visually. Alexandra, after your transit ordeal, I hope you get some clear skies soon. Franco, The full disk was processed without a flat. I had changed the ROI size and the flat frame would not load. Maybe for the best. Stu, Maurits, and Valery, Much appreciated.
Phil
