Dec 13 Full Disk
- Dave S
- Has thanked: 5 times
- Been thanked: 19 times
Dec 13 Full Disk
Not much going on but I replaced my blue glass and wanted to test it. Not a sunspot to be seen. We've now had 268 spotless days this year and on the verge of an historic low. Tomorrow will be 269 spotless days, the most since the year 1913.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: Dec 13 Full Disk
Nice disk image Dave, rain and low altitude of sun where I am so I only get a window of an hour if it's clear then. Well done
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
Thank's for your image Dave and the information on solar minimum.
Martin
Martin
- salvo lauricella
- Has thanked: 56 times
- Been thanked: 75 times
- JochenM
- Been thanked: 1619 times
- Has thanked: 9710 times
- Been thanked: 5766 times
Nice disk. ¿ is that a single or double etalon ?
- Dave S
Thanks! That was with an LS80 double stacked. It's impossible for me to get an evenly illuminated full disc with the DS.
Hi Dave,
Are you able to rotate the upper etalon ? I have my two etalons at an angle of 90°
Rainer
- Been thanked: 4419 times
Hi Dave...
Nice shot of the sun from the 13th!!!
If the scope uses the DSII module I would hope it would be able to produce a more even filed. If you haven't tried to rotate the DSII module relative to the primary one, and also adjusting the pressure in the two to make make the best image. It usually takes some playing around but worth the effort.
- Has thanked: 8543 times
- Been thanked: 8277 times
Nice image, Dave.
Just our luck to have all this technology and masses of kit around the world, primed and ready, for us to experience a ‘century class’ solar minimum.
- Has thanked: 20779 times
- Been thanked: 10459 times
Great image Dave!
- Has thanked: 17970 times
- Been thanked: 8904 times
Nice image Dave, use this image to compare with one in 5 years time, then you will appreciate it
