All,
I have gotten a new Nikon D3500 DSLR camera for Christmas. I hope to use it for solar imaging. I know that it is not going to have the performance that the video stacking method does but I know it can be used. Any advice here? I have the extension tubes for the scopes but I still need to order the T-ring and T-adapter to mount the camera. Also, modern cameras have video modes. Can they be used to acquire the images to stack using the software you guys/gals use to get such magnificent pictures? I know the frame rate is less than the Point Grey Research video cameras preferred by skilled solar photographers. All advice appreciated here.
I should have posted this to the equipment/camera section. Sorry.
DSLR Solar Photography??
- Has thanked: 17853 times
- Been thanked: 16996 times
- Been thanked: 10489 times
Re: DSLR Solar Photography??
No problem posting it here.
Honestly, I would not recommend using a DSLR for solar, either in single shot or video mode. You can use one, but the results you get aren't going to come close to a mono camera.
- Been thanked: 4427 times
Hi James...
Since you already have the camera you can try it out, but as Mark said to purchase one specifically for solar imaging would not be the the best choice.
There have been many WL images posted using a DSLR and it seems to produce reasonable images. The colour filter matrix only allows 1 pixel in 4 to capture red light and 2 covert the green spectrum. This is why they lack for Ha work and do better in WL since the chip sees more of the WL spectrum.
A T-ring is a good investment if you plan to use it on other scopes too...non-solar targets...and as I said no harm in trying solar if you already have it.
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Hello James,
I don't think you need such a camera for solar. You can make much better use of the Nikon. For solar (white light) you would not need your solar telescopes.
A reasonable mono camera could be used. What's more important is your capture equipment. What laptop or acquisition system will you have ?Have you read Montana's solar imaging guide yet . A link is in the reference section - read it at least 2 times. Best of luck!
Magnus
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
Have you read this post viewtopic.php?f=10&t=26988
Some folks do get really good images in Halpha with a DSLR, but it takes a lot of practice and skill. I think most have best success in mono mode. But your resolution will be poor. But, if you have it, use it, why not
All,
I knew the video stacking method was superior the DSLR stills. It shows the evidence clearly on anything that is shot using it. By the sheer number of images taken it helps get around seeing. Just like the eye can momentarily see sharp details in moments of good seeing. The video captures that. I have seen many planetary images so good I would have thought they were taken from orbit! No SLR pictures from years back were ever so sharp. Amateurs take better images now than the pros did less than two decades ago!
My DSLR does have a black and white shooting mode. Would that be like shooting monochrome? And somehow I missed in the holiday hooplah the recent post on DSLR solar photography. Thanks Alexandra! And I will check out your tutorial on solar imaging. I think Mark has one on his Briery Hill Solar website too.
- Has thanked: 9723 times
- Been thanked: 5773 times
Hi James,DeepSolar64 wrote: ↑Sat Jan 11, 2020 9:23 pm All,
Unfortunately no as the Bayer Matrix is still there e.g. RGGB and the H-alfa is in the red so you have only 25% of red.My DSLR does have a black and white shooting mode. Would that be like shooting monochrome?
Putting it in Monochrome mode does only discard the colour information. You really do not take away the Bayer Matrix switching into BW mode.
I have made good White light images using a DSLR but enver managed to get good H-alpha images
Thanks Rainer. It looks like I will have to purchase a monochrome video camera. The better ones are quite pricey though. I need to find a reasonably priced one that has decent performance. Like most things I realize you get what you pay for.
