Full Disc 17 January 2020
- Has thanked: 9414 times
- Been thanked: 5578 times
Just enough time to get a session of 9 Avi with just 250 frames each. Clouds > free > Clouds
While writing this trying to get 4 Avi in White light
Re: Full Disc 17 January 2020
A bit later here the White light image. The old cycle 24 spot is not very visible and perhaps due to the atmospheric conditions not being clear as usual.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Been thanked: 4787 times
- salvo lauricella
- Has thanked: 56 times
- Been thanked: 75 times
- Been thanked: 4340 times
Great images Rainer!!!
I finally had a clear day yesterday, and some time to image at lunch.
- Has thanked: 8418 times
- Been thanked: 8163 times
Nicely done, Rainer. WL is as blank as a Billiard ball. Roll on cycle 25!
- Been thanked: 10247 times
Excellent disks RAiner! Keep them coming!
- Been thanked: 8791 times
Superb discs Rainer! I see the faculae of cycle 24 AR, it is probably very weak so fizzling out. I have a new challenge for you now, polar faculae at the north and south pole are only visible during solar minimum. I see some nice bright points at the north of your WL image and some in the south.
- Has thanked: 1171 times
- Been thanked: 1360 times
Hi Alexandra,Montana wrote: ↑Sun Jan 19, 2020 4:33 pm Superb discs Rainer! I see the faculae of cycle 24 AR, it is probably very weak so fizzling out. I have a new challenge for you now, polar faculae at the north and south pole are only visible during solar minimum. I see some nice bright points at the north of your WL image and some in the south.
I really appreciate all your comments and I have learned a lot from you in the last weeks. Yes, the faculae in my WL image are visible in the same way as from the SDO images.
Yes I have seen little bright spots on North and South Pole. Very interesting. I will need to play a bit with my setup in order to see if I get more details in WL.
I always compare my WL images with SDO in order to see how real my images are.
Thank you very much
Rainer
- Been thanked: 4904 times
