19Jan20 - First Light C11+ARIES D-ERF+Quark (Animated GIF Added)
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Even though the Northeast Monsoon brings many clouds daily during this period there are always gaps for solar imaging. This morning I tried out the C11+ARIES D-ERF+Quark combination. Before I go further, I must thank Alexandria for helping me linked up with a fine gentleman to make the holder for the D-ERF and Valery for various help to set up the quark in good working order.
The setup:
Here is the first image of the morning at 8:30 am local time. I used a unbranded reducer with a 5mm spacer in front of a Basler acA1920-155um USB 3.0 camera. This image is full size, no cropping.
The reducer and spacer:
How do you find the image?
The seeing condition went down hill and more clouds filled the sky after that.
Alfred
The setup:
Alfred
- Has thanked: 8559 times
- Been thanked: 8297 times
Re: 19Jan20 - First Light with C11+ARIES D-ERF+Quark
That setup holds lots of promise, Alfred. The conditions have to be exceptionally good for optimal results. Nice first-light image though with good contrast and detail that can only improve with better seeing. Glad the cell is working well as I designed it for the machining guy that Alexandra found.
- Has thanked: 20828 times
- Been thanked: 10501 times
Does have promise Alfred, but I think the seeing needs to be better to exploit its capabilities to the full.
- Been thanked: 4434 times
Great first light image Alfred
I hope that you can get more favourable conditions to make the most of the large aperture scope...as cycle 25 builds up there will be lots of targets to show its potential.
- Has thanked: 9327 times
- Been thanked: 6163 times
- yltansg
Thanks Stu, Mark, Brian and Franco.
Stu - I really like the design of the cell. Must thank you for that too.
Alfred
Alfred
- yltansg
I found another image taken this morning. I thought it was very noisy and not presentable. Surprising it turned out ok.
I only applied LR deconvolution and unsharp masking processing in ImPPG.
Alfred
Alfred
Hi Alfred,
Excellent results. To make them better you need the first is to make several adapters between the reducer and the camera C-mount thread. This will allow you to rise the S/R ratio, to get better sampling, larger FOV and sharper images. The worser the seeing, the longer adapter should be used and if necessary - crop the frame.
What I can specially note is details contrast.
- Been thanked: 8907 times
Well done Alfred I think you definitely need better seeing and a more active Sun I have my new PST mod to test, I am sure that will take a bit of working out as well
- yltansg
Thanks for the tips, Valery. I found 2 pieces of 5mm spacers and 3 pieces of 10 mm spacers from my cupboard. I will try them out.Valery wrote: ↑Sun Jan 19, 2020 1:58 pm Hi Alfred,
Alfred
- yltansg
Thanks Alexandra. Press on and all the best!!
Alfred
- yltansg
I used the same Daystar Quark with a TPO x0.5 reducer fitted to a 15mm spacer.
Flats shows an increased FOV that requires cropping of the image
Uncropped Single frame
Two images using this reducer setup (please right click to see the full resolution image):
Cropped Image 1
Cropped Image 2
Which one do you like better? Cropped image 1 or 2?
Alfred
Cropped Image 1
Cropped Image 2
Alfred
Re: 19Jan20 - First Light C11+ARIES D-ERF+Quark (New Images Added)
I like the cropped version better. It endeed a very nice start.
I'd make several (2-3) more spacers shorter than this one. Then your setup will be more flexible in choosing of a right scale according to seeing conditions and object of interest nature - prominences, dark filaments, ARs, etc. The fainter the prominence the longer the spacer you need to choose.
BTW The flat shows really excellent uniformity of this Quark especially taking in to accout it's very narrow bandwidth.
Valery.
Valery.
I really like both cropped images, Alfred. So much detail to see, especially the first one. Nicely done.
Phil
Phil
- yltansg
Thanks Valery for the tips.Valery wrote: ↑Mon Jan 20, 2020 8:30 pm I like the cropped version better. It endeed a very nice start.
Valery.
All shops, including machine shops are taking a 2-week break for the lunar new year holiday. Will probably get the shorter spacers in mid Feb. In the meantime I will be using a brand new CAK Quark and a used Quark from Franco.
Alfred
- yltansg
Thanks, Phil. The details are good. I will trying out other quarks to compare the results.
Alfred
- salvo lauricella
- Has thanked: 56 times
- Been thanked: 75 times
Great first light and setup!
Salvo Lauricella
https://www.salvolauricella.it/
- yltansg
- yltansg
Re: 19Jan20 - First Light C11+ARIES D-ERF+Quark (Animated GIF Added)
An animated gif from some good stills. Please do a right click to see the fine details in the animation at full resolution,
A nice addition, Alfred ! Nicely done.
Vey nice animation, Alfred.
I believe no one ever does this at such a scale. Very detailed sun chromosphere boiling!
INteresting thread thanks Alfred.
I do like the animation
- Been thanked: 4981 times
Alfred:
Good imaging and experimentation.
- Been thanked: 4881 times
