Full solar disk 6th Feb 2020
Stardust5858
Post by Stardust5858 » Fri Feb 07, 2020 12:21 am
Hi, just testing my new zwo asi 178mm usb3 with my lunt 60mm double stack today. I had used an older 120mm usb2 b4. Not sure why orientation is different from other image's from the 6th that other people have taken.
JochenM
Re: Full solar disk 6th Feb 2020
Post by JochenM » Fri Feb 07, 2020 4:11 am
Looks good Ella.
I also have to always correct the orientation (when I don't forget that is). I can all vary based on the telescope used, straight through vs diagonal, orientation of the camera etc. All in all, pretty normal.
Post by Montana » Fri Feb 07, 2020 10:03 am
These are terrific! amazing proms! :hamster: :bow
It is always hard to orientate yourself especially when the Sun is so quiet. Sometimes GONG can help http://halpha.nso.edu/index.html#top
rsfoto
Post by rsfoto » Fri Feb 07, 2020 4:24 pm
Very good.
Rainer
Stardust5858
Post by Stardust5858 » Fri Feb 07, 2020 5:55 pm
Thanks peps, appreciate your comments.
MAURITS
Post by MAURITS » Sat Feb 08, 2020 9:40 am
Very nice FD with a lot of fine details.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
PDB
Post by PDB » Sat Feb 08, 2020 10:02 am
yes orientation can be a "problem". I always try to image straight-thru and place the camera so that north (not suns north, but true north). I have 2 ZWO cams the 120 and the 178 and to get a "correct" image I need to place the 120 with the usb connector upwards, and the 178 downwards. (So sensor is reversed in 1 cam). With a diagonal of course you flip one direction, but in FireCapture you can just flip the image independantly on the axis. (If the cam supports, and ZWO does).
Paul
salvo lauricella
Post by salvo lauricella » Sat Feb 08, 2020 3:01 pm
Very nice images! Well done.
Stardust5858
Post by Stardust5858 » Sat Feb 08, 2020 6:32 pm
Paul
Thanks Paul, didn't think to flip, will do this in the future.
Post by MapleRidge » Sun Feb 09, 2020 1:43 pm
Nice set of images !!!
I found that the ZWO camera don't have a common chip/camera body orientation which is a pain.
Post by marktownley » Mon Feb 10, 2020 6:17 am
Nice shots Ella
Post by Carbon60 » Mon Feb 10, 2020 6:49 am
Nice images. As Alexandra says, Gong can be a great help with orientation, whether rotation or ‘flipping’.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
