June 2 2020 Observations
Has thanked: 1248 times
Been thanked: 1335 times
Post by DeepSolar64 » Tue Jun 02, 2020 6:18 pm
Today I observed from 11:00am to 1:30pm EDT local time ( US ). Temp is 77F. Seeing was fair to start with degrading to terrible. Skies are mostly clear.
Coronado SolarMax II 90 DS 32x and 44.5x ( Ha )
Doing double stack I can see the big " feeding animal " prominence on the northern receding limb. The others seen nearby have almost disappeared. A few others can be faintly seen. On the disc the mottling is easy and obvious one you get on-band. The two ARs are remarkably hard to see. A tiny one with a thin filament takes effort and fiddling with the tuner and focuser to see. It is located south of disc center. Two other filaments are visible, again with some re-tuning and focusing and finding the sweet-spot to see. These are more diffuse and are close together near the southeast limb.
In single stack the feeding animal prom shows considerable structure with brighter areas within it with a dark area underneath. This prom has been visible since Saturday evening. I wonder how much longer we will be able to see in before it disappears or recedes around the limb too far to see? A second area on the opposite side of the disc is very active, changes can be seen in a minute or two. Going from a bright bump to a tiny bright curved prom and then disappearing again. Then coming back up diagonally and breaking up into two threads with puffs on the ends! then the base gets bigger, the top fuzes and becomes more diffuse and then the whole thing fades and slowly pulls back towards the sun. All in an hour or so. When I came in it had almost disappeared entirely! I did see a few other small proms around the disc but nothing noteworthy.
Coronado SolarMax II 60DS 16x ( Ha )
Two difficult ARs visible. Two filaments near SE limb. One associated with a tiny AR south of disc center. Two prominence areas seen. The big receding " feeding animal " prominence, as I call it. Looks like a cow today! and a tiny bright prom visible on the opposite SE limb that is associated with some activity there. No other proms seen. Spicule mottling seen across disc.
Celestron NexStar 102GT w/Altair wedge 50x and 83x ( WL )
One AR facula visible on northeast disc. One pore visible within. Becoming difficult as it leaves limb area to see. Granulation visible.
I noticed in double stack that the filaments and the active areas were slightly easier to see in the SM60 than in the SM90. I wonder why. The prominences and disc mottling is better seen in the SM90. In single stack there is no comparison. The 90 destroys the 60! Proms show up in high rez brightness and detail.
dhkaiser
Has thanked: 630 times
Been thanked: 592 times
Re: June 2 2020 Observations
Post by dhkaiser » Tue Jun 02, 2020 6:25 pm
Interesting report. Pretty much what I saw today.
Dan
Lunt LS60THa, Lunt LS60FHa DS
Lunt 102mm ED, William Optics ZS73, Herschel Wedge
Celestron C6 SCT
Ioptron AZ Pro mount, CG-4 mount
ASI 178 mono
South central Indiana
USA
JochenM
Has thanked: 203 times
Been thanked: 546 times
Post by JochenM » Tue Jun 02, 2020 6:41 pm
Nice report. Sound like you got a good view of the dynamic nature of the sun today.
All my images at: https://flickr.com/photos/jochenmaes/
My photography site: http://jochenmaes.com/
Has thanked: 954 times
Been thanked: 821 times
Post by Carbon60 » Tue Jun 02, 2020 8:42 pm
Thanks for the report, James.
eroel
Been thanked: 862 times
Post by eroel » Tue Jun 02, 2020 10:19 pm
James, thanks for the report.
Post by DeepSolar64 » Wed Jun 03, 2020 5:07 am
Thanks, all of you!
David_The_Bears_Fan
Has thanked: 300 times
Been thanked: 120 times
Post by David_The_Bears_Fan » Wed Jun 03, 2020 6:38 am
Interesting to compare your H Alpha observations with what I see in Ca-K, thanks.
David
Has thanked: 2190 times
Been thanked: 843 times
Post by marktownley » Wed Jun 03, 2020 7:51 am
Good report James! Big shift in weather patterns here in western Europe now, raining today, gone are the weeks of sunshine and back to something more stereo typically British, looks like i'm back to fishing in the gaps.
yltansg
Has thanked: 675 times
Been thanked: 317 times
Post by yltansg » Wed Jun 03, 2020 9:04 am
Thanks James for your narrative report. It makes it interesting.
Alfred
Has thanked: 708 times
Been thanked: 388 times
Post by ffellah » Wed Jun 03, 2020 9:58 am
Very detailed observations, James. Thank you.
EGRAY_OBSERVATORY
Been thanked: 781 times
Post by EGRAY_OBSERVATORY » Wed Jun 03, 2020 10:22 am
Excellent images James and thanks
