7Jun - AR 2765 in HA & WL - new image added on 13June
yltansg
Has thanked: 1455 times
Been thanked: 1444 times
Post by yltansg »
It has been raining for several days. The morning started with tons of clouds. Then we had some blue in between clouds. Taking a break from trying to resolve the reflection in the CAK image, I did some HA and WL imaging with the following setup:
Here is an image of AR2765:
It was made from stacking 1000 frames. The settings in Firecapture, using an ASI174: Exposure: 3.148ms, Gain : 25554, Gamma : 3.34. Processing was done with ImPPG with the usual tone curve stretch and minimal touch-up (contrast and level adjustments) in Photoshop. It is one of the cleanest images taken today.
Alfred
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Re: 7Jun - AR 2765 in HA
Post by p_zetner »
Nicely done, Alfred.
Peter
arnedanielsen
Has thanked: 6276 times
Been thanked: 7298 times
Post by arnedanielsen »
Nice work Alfred!
Arne
Arne
AstroBin: https://www.astrobin.com/users/arnedani/
Been thanked: 4959 times
Post by eroel »
Alfred, a very nice result with just few holes in the clouds to work with.
dhkaiser
Has thanked: 1407 times
Been thanked: 899 times
Post by dhkaiser »
Looks like a bullet hole. Nice detail.
Dan
South central Indiana
USA
RodAstro
Has thanked: 286 times
Been thanked: 399 times
Post by RodAstro »
Nice
Rod
rsfoto
Has thanked: 9694 times
Been thanked: 5760 times
Post by rsfoto »
Very nice
Has thanked: 20757 times
Been thanked: 10442 times
Good result Alfred!
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
And I notice " Solaris " in the background.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
A crack-shot into that dark hole - well done
Regards
Has thanked: 17925 times
Been thanked: 8894 times
Beautiful Alfred! really beautiful :bow :bow :hamster:
How did you get on in white light? I didn't know you could use a Herschel wedge on an SCT.
Montana wrote: Mon Jun 08, 2020 7:42 am I didn't know you could use a Herschel wedge on an SCT.
Only if you use the DERF too.
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Came out great, Alfred.
Jochen Maes
Belgium
https://www.jochenmaes.com
yltansg
Post by yltansg »
Thank you for your kind comments, Peter, Arne, Eric, Dan, Rod, Rainer, Mark, Mark, James, Terry, Alexandra and Jochen.
James - Solaris is one of our groups in School. Of course they are glad that solar telescopes are available for all to use.
ALexandra and Mark, Yes, I used the ARIES D-ERF (stepped down to 220mm) and a x5 powermate with the Herschel wedge. Unfortunately the clouds came in and covered the whole sky. I only managed to capture 1 shot on the background. Did not manage a shot on the active regions.
This is that one WL image:
yltansg
Re: 7Jun - AR 2765 in HA - More images added on 8 June
Post by yltansg »
This is the other active region in the northern hemisphere that may not have attracted the same attention:
It is mosaic of 2 images.
Alfred
Re: 7Jun - AR 2765 in HA & WL - More images added on 8 June
Excellent closeups Alfred!
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
Great close up, Alfred. And granulation shots.
yltansg
Post by yltansg »
Thanks Mark and Franco. Unfortunately the weather went south and no chance to do any more imaging of these 2 ARs.
Alfred
Has thanked: 8523 times
Been thanked: 8259 times
Lovely images, Alfred. Hopefully the weather will improve soon to enable you to get back into action.
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
Wonderful images.
Marios S.Ioannou
Sketcher/Visual Observer
pedro
Has thanked: 14 times
Been thanked: 6686 times
Post by pedro »
great images there Alfred
yltansg
Post by yltansg »
Thanks Stuart, Marios and Pedro.
Stuart, although we have the rainy season, there are always windows of good seeing if I am patient enough to catch one.
My C11 is left on the mount and covered with canvas (a 3-layer covering) when not in use.
With this setup (leaving the C11 outside under a 3-layer covering), it is a bit tricky because the humidity is usually high and it becomes worse during the raining season. However this setup has worked well for me and the equipment has retained its condition well with regular maintenance.
I wonder if there if any of you leave your telescope on the mount (covered of course) when not in use. Our humidity varies from sixties to nineties percent.
Alfred
EGRAY_OBSERVATORY
Re: 7Jun - AR 2765 in HA & WL - new image added on 13June
Hi Alfred,
The humidity can be the worst part of the damp-problem - if not able or willing to bring the gear inside.
I use a dehumidifier in my observatory to keep the damp at bay, with typical humidity of 40%, which at least dries out any dampness after the roof is closed after a session days or nights...
Before completion of my observatory, the stand and it's electrics were covered-up like your photos for over two years with no degradation, but not the scope or mounts...
Cheers
Derek Klepp
Been thanked: 171 times
Post by Derek Klepp »
Alfred great pics .My scopes stay on their mounts but are wheeled out of the shed. I,ll admit though that I am only just starting to get back into solar viewing and photography after a couple of slack years.My biggest problem is the shed computers pack it in.So now its a laptop.
I have been very impressed with your images and it seems you have got your setups wrking extremely well.
Derek
yltansg
Post by yltansg »
Derek Klepp wrote: Sun Jun 14, 2020 7:31 am Alfred great pics .My scopes stay on their mounts but are wheeled out of the shed. I,ll admit though that I am only just starting to get back into solar viewing and photography after a couple of slack years.My biggest problem is the shed computers pack it in.So now its a laptop.
Derek
Hi Derek,
Glad to know you are getting back into solar work again. Looking forward to seeing your images again.
Take care, my friend.
Alfred
p_zetner
Post by p_zetner »
Lovely WL and H alpha additions, Alfred.
My mount stays outside and is covered but I'm not bold enough to leave the scopes outside!
Peter
