AR 2765 and the long filament - June 7, 2020
- Has thanked: 9327 times
- Been thanked: 6163 times
Hello everybody: a beautiful sunny day today with below average seeing. After a very long time waiting, I received a Solar Spectrum loaner filter while my one is being repaired. I thought I would give it a try with the large scope, notwithstanding the poor seeing. AR 2765 is beautiful and there was this very long filament.
I definitely had fun. Hope you also had a chance to spend some time with the sun this weekend.
- 081009 final mono.jpg (1.38 MiB) Viewed 1551 times
- 081009 final mono inverted.jpg (1.34 MiB) Viewed 1551 times
- 081009 final color.jpg (1.68 MiB) Viewed 1551 times
- 081147 final mono.jpg (1.21 MiB) Viewed 1551 times
- 081147 final mono inverted.jpg (1.19 MiB) Viewed 1551 times
- 081147 final color.jpg (1.56 MiB) Viewed 1551 times
- 085210 final mono.jpg (1.14 MiB) Viewed 1551 times
- 085210 final mono inverted.jpg (1.14 MiB) Viewed 1551 times
- 085210 final color.jpg (1.44 MiB) Viewed 1551 times
- 085242 final mono.jpg (1.34 MiB) Viewed 1551 times
- 085242 final mono inverted.jpg (1.34 MiB) Viewed 1551 times
- 085242 final color.jpg (1.64 MiB) Viewed 1551 times
- Conditions.jpg (743.45 KiB) Viewed 1551 times
- Has thanked: 17859 times
- Been thanked: 17003 times
Re: AR 2765 and the long filament - June 7, 2020
Franco,
Those are stunning views of that large filament. I wish I could get this kind of sharpness, resolution and magnification visually.
- Been thanked: 4981 times
Franco:
Super shots all of them.
James, Eric: thank you very much for your kind words.
I apologize, specially to Rainer, as the images are incorrectly oriented: they are all upside down
Originally they were correct, then for some reason I flipped them
What the heck...
What the heck...
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
All Right, Franco! Looks like you're back in business and making that loaner work well. Just curious, is it the same model as yours or did they slip you a RG instead?
Phil
Phil
Thank you Dan and Phil. It is the same case but he replaced the etalon with a new one that runs hot (64 Celsius). The filter works but I definitely prefer my original etalon that run at a cooler 38 Celsius. This one also quickly drained one of my portable batteries.
- Has thanked: 174 times
- Been thanked: 619 times
Franco,
Great result, excellent presentation.
If that's "below average seeing" just wait to you visit over here in the Bellarine....I'll show you BELOW average seeing.
Well done.
Well done.
Franco,
Interesting about the operating temperature. I run mine at about 59.0°C using AC power. Sometimes it would be nice to battery power the unit I have and I'm curious as to the battery you use and the run times.
Phil
Phil
- Has thanked: 20828 times
- Been thanked: 10502 times
You got a lovely set of images in Franco!
- JochenM
- Been thanked: 1619 times
Thank you Ken, Mark and Jochen. Greatly appreciated.
Yes Franco, definitely an excellent set of images and information too.
The filaments show-up very well
Thanks
Thanks
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Fantastic images, Franco, and very well processed. Are you sure you want back your solar spectrum ? I would keep this one instead...
Raf
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
Hi Franco,
Lovely images. The long filament, spots, penumbra and the fibrils made a nice setup.
Alfred
Alfred
- Been thanked: 8907 times
Fantastic Franco!!! these are magnificent
Bad seeing!! wow you are a tough person to please can't wait to see the results with good seeing then
- pedro
- Has thanked: 14 times
- Been thanked: 6696 times
Great set of images Franco
Pedro Re'
Thank you Terry, Raf, Jozef, Alfred, Rod, Peter, Alexandra and Pedro for your very kind words.
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Beautiful images!
Marios S.Ioannou
Sketcher/Visual Observer
- Ronnie_Clayton
- Has thanked: 10 times
- Been thanked: 130 times
Beautiful job Franco, especially by the level of fine details...
Thanks a lot, Ronnie. I always enjoy you postings.
Hi Ffellah,
Your image is in the red wing( +.5Ang). That is a good example of what the red wing looks like.
I would drop the temperature 2 or 3 deg first and see the difference. When you are in the center of the Ha line, it will have a softer look. The tips of the photosphere will have less contrast. When you are in the blue wing . I always think of it as salt and pepper looking. If you take the temperature down 8 deg and you should be about .5Ang in the blue wing.
Just as aside note, most of the action is in the blue wing. You can have erupting filments one or two ang blue shifted that you would miss when the filter is on band.
Give it a try
Mark W.
Give it a try
Mark W.
- Has thanked: 8559 times
- Been thanked: 8297 times
A super set of images, Franco. Good to see you back in action.
