FD June 8, 2020
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
FD June 8, 2020
I think I might be getting a handle on the uneven illumination by rotating the DS. Thanks to suggestions here.
Dan
South central Indiana
USA
USA
- Has thanked: 9145 times
- Been thanked: 6026 times
- Has thanked: 9417 times
- Been thanked: 5583 times
Re: FD June 8, 2020
Hi Dan,
Very good. Looks similar to what I get. As we can see the Hot spot is a bit on the rght side of the surface. This can be eventually corrected by doing like explained below.
1. I recommend now to set both etalons to zero position 0°. I guess you will notice a Ghost Sun. Now move the adjustment of the lower etalon until the second Sun disappears from the FOV.
2. Having that, start adjusting the second etalon until you have the Hot Spot in the center of the Sun.
Point 1 and 2 that is how I adjust my etalons. So I really do not know if it works with a Lunt as I have Coronado.
In order to set 0° I use a Feeler gauge (Blade feeler) and measure the separation at the hinge and that same distance I put it where the golden adjuster wheel is and here is where Lunt differs from the Coronado as I guess the hinge is not visible in the lunt eatlon ¿?
- dhkaiser
Re: FD June 8, 2020
Thanks Rainer, not sure how to do that with a Lunt PT.
Dan
USA
USA
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Re: FD June 8, 2020
10 points...Beautiful picture Dan!
Marios S.Ioannou
Sketcher/Visual Observer
- Been thanked: 10248 times
Re: FD June 8, 2020
Good image Dan. I always used a piece of card that I cut into a gasket to sit below my external etalon, this allows to clock the etalon to the position you want that gives most even field. Just use card of differing thicknesses to get to desired position.
Re: FD June 8, 2020
Hi Dan,
Is there a way to see the gap ?
Re: FD June 8, 2020
What I did was, find the correct angle and then wound a electrical insulation tape around it so it could not move anymore.marktownley wrote: ↑Mon Jun 08, 2020 7:48 pm Good image Dan. I always used a piece of card that I cut into a gasket to sit below my external etalon, this allows to clock the etalon to the position you want that gives most even field. Just use card of differing thicknesses to get to desired position.
Another way to make this big washers is to print them on acetate sheets for presentation and cut them out and so you can stack them until you reach the correct distance. Acetate does not compress.
- dhkaiser
Re: FD June 8, 2020
Good ideas guys, thanks. Until I find the ideal position I am using the label on the DS as an index.
Dan
USA
USA
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
Re: FD June 8, 2020
Cracking disk Dan
David
- JochenM
- Been thanked: 1619 times
- Has thanked: 17581 times
- Been thanked: 16697 times
Re: FD June 8, 2020
Very nice. Looks correctly oriented too!
- Has thanked: 8418 times
- Been thanked: 8165 times
Re: FD June 8, 2020
That’s a really fine FD, Dan. Your images are coming along in leaps and bounds, as we say.
Double stacking can be really fiddly. Sometimes I can pretty much point and shoot with little effort and other times I struggle to get on band and even illumination across the disk. Tuning in SS mode first and then adding the DS module and tuning/clocking that second often helps, but even then there’s a bit of fine tweaking of both required to achieve optimum results.
Nicely done.
Nicely done.
- nicosolcy
- Has thanked: 1212 times
- Been thanked: 906 times
Re: FD June 8, 2020
That's a great FD and I need to start using my DS module too! The difference between your stuff and my stuff (I still only use SS) is dramatic.
Nick
Photosphere Junkie!
Lunt 40mm SS FTF
Photosphere Junkie!
Lunt 40mm SS FTF
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Re: FD June 8, 2020
Excellent FD with lot of details!
Raf
- Been thanked: 8793 times
