June 11, 2020 AR12765 using Questar/Quark + June 12
Astrophil
Been thanked: 141 times
Post by Astrophil » Thu Jun 11, 2020 8:33 pm
Hi All,
Another clear morning, what a nice surprise. Today I took the little Questar out from the shadows, where it has been hiding for many months, and showed it the sun. Attached to the axial port was a 2.5x Powermate followed by the Quark Combo a .5x focal reducer and PGR camera. A Baader DERF was mounted on the front.
With only one main target, AR12765, and with no clouds it did not take very long to capture all the videos I needed. I had seen Questar imagers using the built in diagonal and eyepiece port on the scope to image so I thought I'd give it a try. It seemed a bit unwieldy to stick the Powermate, Quark, and camera into the eyepiece port. I can see how image orientation can get a little confusing.
The first image is the normal axial setup. The rest of the images were taken from the eyepiece port without proper orientation unfortunately.
Phil
EGRAY_OBSERVATORY
Been thanked: 588 times
Re: June 11, 2020 AR12765 using Questar/Quark
Post by EGRAY_OBSERVATORY » Thu Jun 11, 2020 9:03 pm
Whichever way round Phil, these images are well good and AR2765 certainly shows all.
Thanks
rsfoto
Has thanked: 1292 times
Been thanked: 919 times
Post by rsfoto » Thu Jun 11, 2020 9:31 pm
Very good
Has thanked: 564 times
Been thanked: 312 times
Post by ffellah » Thu Jun 11, 2020 9:50 pm
These are super, Phil.
Franco :bow
eroel
Been thanked: 724 times
Post by eroel » Thu Jun 11, 2020 9:54 pm
Phil:
Very nice session, at my place it clouded all day.
dhkaiser
Has thanked: 575 times
Been thanked: 532 times
Post by dhkaiser » Thu Jun 11, 2020 10:03 pm
I like the mono best, great images.
Dan
Lunt LS60THa, Lunt LS60FHa DS
Lunt 102mm ED, Herschel Wedge
Celestron C6 SCT
Ioptron AZ Pro mount, CG-4 mount
ASI 178 mono
South central Indiana
USA
RodAstro
Has thanked: 151 times
Been thanked: 164 times
Post by RodAstro » Thu Jun 11, 2020 10:29 pm
Very nice Phil
Awesome little scope
Rod
yltansg
Has thanked: 638 times
Been thanked: 278 times
Post by yltansg » Thu Jun 11, 2020 11:50 pm
Hi Phil,
The details are incredible coming from a small scope. It is fits its reputation in the hands of an expert.
Would be nice to see a photo of your setup with the Questar.
Alfred
Astrophil
Post by Astrophil » Fri Jun 12, 2020 1:18 am
Sure Alfred. Here is today's setup.
Phil
Starry Jack
Has thanked: 94 times
Been thanked: 131 times
Post by Starry Jack » Fri Jun 12, 2020 1:49 am
Yikes those are pretty
Aeries D-ERF
12nm Filter
ZWO174 (IMX249 chip 5um)
JochenM
Has thanked: 167 times
Been thanked: 506 times
Post by JochenM » Fri Jun 12, 2020 4:01 am
Nice result, Phil.
Love the setup as well :)
All my images at: https://flickr.com/photos/jochenmaes/
My photography site: http://jochenmaes.com/
Has thanked: 1023 times
Been thanked: 1161 times
Post by DeepSolar64 » Fri Jun 12, 2020 5:02 am
Phil,
Your images show incredible depth as well as sharpness! And what type/brand of mount is your setup mounted on?
Has thanked: 2079 times
Been thanked: 719 times
Post by Montana » Fri Jun 12, 2020 7:10 am
Wow!! your images are always flawless :bow :hamster: you have an excellent Quark too :)
marios i.
Has thanked: 434 times
Been thanked: 157 times
Post by marios i. » Fri Jun 12, 2020 8:12 am
Very nice images.
Sketcher - Visual Observer
Has thanked: 28 times
Been thanked: 106 times
Post by Valery » Fri Jun 12, 2020 10:09 am
Excellent seies, Phil! And a very nice Questar setup.
Thanks for sharing.
EGRAY_OBSERVATORY
Post by EGRAY_OBSERVATORY » Fri Jun 12, 2020 10:36 am
Nice set-up there Phil and well done on the fab imaging
Astrophil
Re: June 11, 2020 AR12765 using Questar/Quark + June 12
Post by Astrophil » Sat Jun 13, 2020 2:20 am
Another day with the Questar/Quark Combo setup. This time I tried three different scales using the .5x focal reducer with an additional 5mm spacer attached. This produced the maximum field of view with all four corners being cut off. I had to reduce the ROI to avoid vignetting. The first image is with the reducer plus the spacer, next is with the spacer removed and lastly with no focal reducer. Two inverted images are included to show a nearby prom.
Phil
Has thanked: 811 times
Been thanked: 710 times
Post by Carbon60 » Sat Jun 13, 2020 7:09 am
Fabulous images, Phil. That’s a heck of a setup, producing wonderful images.
Post by Montana » Sat Jun 13, 2020 7:27 am
Wow! the last image looks like a rearing horse!
solarGain
Has thanked: 4 times
Been thanked: 70 times
Post by solarGain » Sat Jun 13, 2020 8:44 am
Excellent images from a perfect telescope. Well done.
John
