Full disk 02-07-2020
- Has thanked: 9723 times
- Been thanked: 5769 times
Imaging the Sun is 10 % experience and 90% cloudless sky and some luck.
Again not much cloudless Sky but enough time to get my minimum amount of videos for making my disks.
The filament train in the Northeastern quadrant is still there just changing a bit its form. A very nice fine and big prominence on the Northwestern limb.
As rusted said there is a surface perturbation in the Northeastern quadrant at +23° and -63° with a bird shape or maybe a Dragonfly ¿? with cycle 25 polarity.
There are two more surface perturbations in the Northeastern quadrant with the center at -15° and +35°. Looking at the HMI image of SDO the right side is positive and the left side is negative.
The still unnumbered spot in the Southeastern quadrant at -24° and -30° has a clearly defined cycle polarity +/-. Left of it on perturbation also with cycle 25 polarity with its center at about -60° and -30°.
All over the surface some fine filaments. A nice big prominence on the limb in the Soutwestern quadrant and a very tiny prominence at the Soutwestern limb at about -42°.
In the white light image there I see one and a half pore from the unnumbered spot as well as the plages of the two surface perturbations near the limb are visible.
As usual best seen in full size in new tab/window. Thanks for dropping by
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Has thanked: 9313 times
- Been thanked: 6151 times
- Been thanked: 4976 times
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
Re: Full disk 02-07-2020
Nice work as always, Rainer. That disk is starting to look a bit more lively again.
- Has thanked: 17849 times
- Been thanked: 16986 times
Very nice work as typical of you Rainer. You captured all those filaments superbly. You also got all those perturbations too. I somehow overlooked the dragonfly one. I think I was too distracted by all those nice filaments nearby.
- Has thanked: 8556 times
- Been thanked: 8287 times
Very nice FDs, Rainer. Nice sharp and clear filaments and proms. Nearly a vertically aligned Sun.
Excellent and interesting surface-detail Rainer.
Thanks for sharing
Regards
Thanks for sharing
Regards
Super stuff Rainer, your posts are always more informative than Spaceweather and GONG put together
- Rusted
- Has thanked: 8167 times
- Been thanked: 1943 times
Incredibly sharp detail!
- Has thanked: 20784 times
- Been thanked: 10477 times
Great views Rainer!
Thanks everybody
Thank You Peter
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Excellent!!!
Marios S.Ioannou
Sketcher/Visual Observer
