A bit late posting these for a number of reasons (busy Sunday + my laptop seems to have develop an aversion to connecting to our router all of a sudden). Yesterday was the first decent session with both the Quark and the Evostar 120. Although the seeing was quite variable at times at least the winds had dropped so I could use the big scope. I spent quite a bit of the session just visually working through different combinations of barlow, aperture mask and Quark settings to try and get the best views and then plugged the 178 in for a whole lot more fun. First few images below plus the usual Ca-K disk and a bit of white light as well. Second shot is clearly suffering with Newtons Rings although the first image is much better. The first image was shot and processed using a separate flat field file / capture whereas the second was shot using Fire Captures built-in live flatfield option. Need to experiment further with this. I'm reasonably pleased with how these came out for a first session, with time and effort these will improve over the coming weeks and months....I hope!
The Sun - 12th July 2020
- David_The_Bears_Fan
- Has thanked: 423 times
- Been thanked: 167 times
David
- Been thanked: 16691 times
Re: The Sun - 12th July 2020
David
Those are wonderful views of the spicule layer on the solar limb.
- JochenM
- Been thanked: 1619 times
Nice results, David.
I have newton rings by default on my Quark as well. Tilting the camera very slightly (probably the least amount of tilt I can set the adapter to) eliminates this completely.
- Has thanked: 8415 times
- Been thanked: 8161 times
Very nice first lights, Dave.
- Has thanked: 9144 times
- Been thanked: 6025 times
- Been thanked: 4904 times
- Has thanked: 20424 times
- Been thanked: 10243 times
Good collection David!
