AR2768 & AR2769 High Res | HA & CaK | Aug 2nd 2020
- Been thanked: 1390 times
Heya,
It's been storming lately a lot, hurricane season and all, our local hurricane finally downgraded to a tropical storm again and is south of me. While hurricanes are nasty for weather, they're great for seeing conditions as they push the air around making laminar flow here and there which leads to rather good seeing. I recorded some of my best seeing averages with the SSM today, right at sunrise over my tree line, for about an hour. Almost all of it was sustained sub-arc-second and was seeing quite a bit of 0.3" to 0.4" moments on the monitor. Anyhow, it's really nice that AR2768 is around with a lovely mottled plage and AR2769 is chasing it with a wee spot and some interesting plage area too. The large prom is gone, so I wasn't able to see it due to weather prior. With such seeing today I was able to get enough data to do a high resolution mosaic of AR2768 & AR2769 as one image. I then gathered just AR2768 in Ha & CaK and then did some smaller image scales with an 80mm and 60mm setup for comparisons as the activity and filaments makes for an excellent wide field view. For the high res data on a 150mm aperture refractor, a single 50mm internal sub-aperture D-ERF was used for both the HA & CaK.
B&W:
High Res AR2768 & AR2769 HA Mosaic:
(Click the link for the full resolution)
AR2768:
AR2768 & AR2769 Partial Discs:
Colored:
AR2768:
Seeing Conditions:
Equipment:
150mm F8 Refractor
+ Baader Red CCD-IR Block Filter (50mm sub-aperture internal D-ERF) + Baader GPC 1.25x (F10) + PST 1A HA Etalon + 10mm BF + ASI290MM
(Masked to 120mm F10) + Baader Blue CCD-IR Block Filter (50mm sub-aperture internal D-ERF) + Lunt CaK B1200 + 2x Barlow (F20) + ASI290MM
80mm F7.5 Refractor
+ Solarmax 60mm II Etalon (F10) + PST 1A HA Etalon + 10mm BF + ASI290MM
+ Lunt CaK B1200 + ASI290MM
B&W:
AR2768:
Colored:
AR2768:
Seeing Conditions:
Equipment:
150mm F8 Refractor
80mm F7.5 Refractor
- Been thanked: 5016 times
Re: AR2768 & AR2769 High Res | HA & CaK | Aug 2nd 2020
Marty:
Super session.
Best regards and keep well.
Super session.
- Has thanked: 1283 times
- Been thanked: 1071 times
Gorgeous, thanks vm for posting. Lucky seeing, Marty! I had 1.8" today only.
regards
Leo
regards
Leo
- Has thanked: 9816 times
- Been thanked: 5823 times
Hi Marty,
Excellent close up images.
- JochenM
- Been thanked: 1619 times
Now that's some seeing right there!
Brilliant images, Marty. An absolute joy to watch.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Lucky you with that seeing.
Dan
South central Indiana
USA
USA
Hi Marty,
Some cracking images with such fine detail, so thanks vm
- Has thanked: 20940 times
- Been thanked: 10587 times
A really excellent set of images Marty, i'm glad you got some good seeing as a result of bad weather. Hope it continues!
- Has thanked: 9387 times
- Been thanked: 6199 times
Top shots, Marty, with great detail and contrast. This type of sessions are very rare, you are lucky you had one (minus the hurricane)
Thanks all,
Amazing we've had 4 AR's in one go in a few days after so many weeks of nothing!
- Has thanked: 17955 times
- Been thanked: 17100 times
I would have never guessed that hurricanes would help local seeing. Excellent images as usual Marty.
It's odd, but I've always noticed seeing was better when there were storms pushing things around. Not little showers, but big storm systems. A hurricane is a big hot temperature super cell system that is pushing the surrounding columns around generating a gradient of pressure, this produces directional air flow that can be laminar in some regions and that will produce the best seeing conditions for that particular area. I try to be ready before/after any storm if there's a chance that it passes and there's clear spots between the rain (benefit of an observatory) for this reason.DeepSolar64 wrote: ↑Mon Aug 03, 2020 5:06 pm I would have never guessed that hurricanes would help local seeing. Excellent images as usual Marty.
Finally having an SSM to put a metric to my anecdotal experience has been fun, great to see validation on seeing conditions when I think they're good or bad and can see a metric corresponding to it. It's also been great to correlate seeing conditions and what image scales with apertures I can attempt and at different wavelengths. I've yet to max out 393nm for example, just don't get that 0.3" seeing sustained often enough!
So while I'm not on a mountain top in France, or on the coast of an island in the Southern hemisphere, crazy storms do a pretty interesting thing to the peninsula on the Gulf of Mexico!
- Has thanked: 65 times
- Been thanked: 4459 times
An excellent series of images Marty in all bands
Interesting how your seeing is influenced by the storms on the east coast of Florida, but the laminar flow makes sense. So long as it isn't 100+ MPH flow locally its good
Indeed that Brian! 75 MPH = Hurricane Cat 1. I had one roll me over a few years ago (Hurricane Irma), rolled over my house/observatory. My live oak trees handled it though so my garbage cans didn't even fall over. The observatory buckles down in each corner and handles it so far. I wouldn't likely survive a Cat 3 or greater if it actually hit me though. So yea, hoping to not see those 100MPH+ sustained winds!
- Has thanked: 18105 times
- Been thanked: 8941 times
Some really beautiful panoramas Marty and what a delight the close up CaK is
