AR's 2770 (Light Bridge!), 2769, 2768 in High Res 200mm HA | Full Discs HA, CaK, WL | Aug 9th 2020
- Has thanked: 1171 times
- Been thanked: 1360 times
Hey all,
The sky was relatively clear this morning so I was able to take a look at AR's 2770 with its spot & light bridge, 2769 with its filament and 2768 as it rounds the limb with lots of mottling still. I managed to get some high res data with the 200mm with pretty good seeing. Clouds rolled in fast, so sadly the rest is courser scale and I was slightly off focus for the photosphere image of 2770's spot and cells. Managed some discs in HA, CaK & WL (610nm) with a smaller 80mm refractor for comparison.
B&W:
Colored:
Trifecta of Discs:
Seeing Conditions:
Equipment:
C8 Edge HD + Aries 214mm TriBand D-ERF + Baader Red CCD-IR Block Filter 2nd D-ERF
+ Coronado 1A PST Etalon + 10mm BF + ASI290MM (HA)
+ Baader 610nm + Baader ND3.0 + ASI290MM (WL)
ED80 Frac
+ Solarmax 60 II + 1A PST Etalon + 10mm BF + ASI290MM (HA disc)
+ Baader 610nm + Baader ND3.0 + ASI183MM (WL Disc)
+ Lunt B1200 CaK Filter + ASI183MM (CaK Disc)
B&W:
Colored:
Trifecta of Discs:
Seeing Conditions:
Equipment:
ED80 Frac
- Been thanked: 16694 times
Re: AR's 2770 (Light Bridge!), 2769, 2768 in High Res 200mm HA | Full Discs HA, CaK, WL | Aug 9th 2020
Marty,
Stunning image on all accounts! Stunning AR filament views in Ha, and I love the spot detail in WL. It shows the light bridge that splits the umbra into two and shows those tiny pores and granules so well. CaK shows up the AR plages superbly!! BIG thumbs up on these!!
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Wonderful hi res details Marty!
Dan
South central Indiana
USA
USA
- Has thanked: 9414 times
- Been thanked: 5578 times
Hi Marty,
Very good.
Very good.
- Been thanked: 8792 times
Glorious feathery detail Marty, super images
- JochenM
- Been thanked: 1619 times
Excellent capture of that light bridge, Marty (and the rest is not too shabby either ).
- Been thanked: 2713 times
Great shots Marty !
There was some indication of first development of the light bridge on the Ca K image I took on August 7. It only took two days to split this small spot in two !
- Has thanked: 9145 times
- Been thanked: 6025 times
A splendid set, Marty !
- Been thanked: 4787 times
- Been thanked: 10247 times
A very impressive set of images indeed Marty! Glad the seeing was on your side!
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Love the HR images with the 200mm Marty, well done
Pedro Re'
- Has thanked: 8418 times
- Been thanked: 8163 times
Beautiful images, Marty. Looks like you had a very busy session.
