Spot, Granulation, Facula, Pattern in KLine with a T300
allhoest
Been thanked: 39 times
Post by allhoest » Thu Aug 20, 2020 6:34 pm
Hi!
Here a first set of pics taken from St Véran (French Alps) with a non aluminized 12" mirror.
The pics are taken in KLine (296nm).
CS
Alex
2020-08-9 & 14
Solar newton T300 F1800
FFC
KLine
ASI174
Has thanked: 992 times
Been thanked: 529 times
Re: Spot, Granulation, Facula, Pattern in KLine with a T300
Post by ffellah » Thu Aug 20, 2020 6:38 pm
Fabulous, Alex. Very sharp.
solardave
Has thanked: 10 times
Been thanked: 65 times
Post by solardave » Thu Aug 20, 2020 6:47 pm
fantastic job
tak 102fs solarmax40 ds es ed80 cornado 90mm filter bf10 bf 30 skynyx 2-2 mono camera lunt 2inch wl wedge lunt b1800 cak mod
Has thanked: 2028 times
Been thanked: 1913 times
Post by DeepSolar64 » Fri Aug 21, 2020 4:47 am
Alex,
I thought at first these were taken in Continuum until I read your post. The supergranules of the lower chromosphere look a lot like the granules of the photosphere but are a bit larger. Your resolution is excellent here! Very nice images!!
JochenM
Has thanked: 353 times
Been thanked: 676 times
Post by JochenM » Fri Aug 21, 2020 9:46 am
Excellent work, Alex.
I also thought I was looking at the photosphere in that first image until I noticed the finer detail. Absolutely stunning capture!
Has thanked: 3159 times
Been thanked: 1214 times
Post by Montana » Fri Aug 21, 2020 11:49 am
Absolutely incredible imaging :bow :bow :bow I presume this is the Photosphere granulation with faculae visible around the spot. Is this the Baader K line filter? as this only shows the photosphere with enhanced faculae, however, you confuse me with 296nm?
krakatoa1883
Has thanked: 76 times
Been thanked: 261 times
Post by krakatoa1883 » Fri Aug 21, 2020 12:27 pm
Fantastic granulation detail :bow
Raf
allhoest
Post by allhoest » Fri Aug 21, 2020 6:20 pm
Hi!
Thanks for the comments.
Yes, I used a Baader KLine filter at 396nm (not 296nm!).
CS
Alex.
sulcis2000
Been thanked: 135 times
Post by sulcis2000 » Fri Aug 21, 2020 6:58 pm
TOP!
Alessandro Bianconi
________________
Celestron C14HD Edge
Refractor 228 F8 Truss Tube with D-ERF 110mm
A&M Refractor APO LZOS 130 F6
Lunt50 B600 Pressure Tuned
Daystar Quark Chromosphere version
Daystar Quark Calcium H
Starizona Hypestar V4
10 Micron GM2000HPS II Mount
Ioptron CEM120 Mount
ZWO ASI2600MC Pro
ZWO ASI178M Cooled
ZWO ASI178MC Cooled
ZWO ASI174M
grimble_cornet
Been thanked: 47 times
Post by grimble_cornet » Fri Aug 21, 2020 9:06 pm
Amazing resolution!
Mike Garbett
eroel
Been thanked: 1143 times
Post by eroel » Fri Aug 21, 2020 10:36 pm
Alex:
Superb resolution.
LeoD
Has thanked: 122 times
Been thanked: 150 times
Post by LeoD » Sun Aug 23, 2020 6:18 pm
Incredible images! All together, setup, high altitude and the author of course, gives a fantastic result!
regards
Leo
allhoest
Post by allhoest » Sun Aug 23, 2020 6:30 pm
Thank you again for the comments.
Leo, you would wonder my setup: the mirror is an old mirror from the 80's which has been converted to solar, the truss and other parts are second hand, which I adapted a bit in my garage.
The old F6 optic looks to be good and I have a good secondary also.
I should give a try with this setup in my area.
CS
Alex
