Spot, Granulation, Facula, Pattern in KLine with a T300
allhoest
Has thanked: 714 times
Been thanked: 496 times
Post by allhoest »
Hi!
Here a first set of pics taken from St Véran (French Alps) with a non aluminized 12" mirror.
The pics are taken in KLine (296nm).
CS
Alex
2020-08-9 & 14
Solar newton T300 F1800
FFC
KLine
ASI174
Has thanked: 9292 times
Been thanked: 6128 times
Re: Spot, Granulation, Facula, Pattern in KLine with a T300
Post by ffellah »
Fabulous, Alex. Very sharp.
solardave
Has thanked: 10 times
Been thanked: 219 times
Post by solardave »
fantastic job
tak 102fs solarmax40 ds es ed80 cornado 90mm filter bf10 bf 30 skynyx 2-2 mono camera lunt 2inch wl wedge lunt b1800 cak mod
pedro
Has thanked: 14 times
Been thanked: 6684 times
Post by pedro »
Fantastic resolution Alex
Has thanked: 17813 times
Been thanked: 16948 times
Post by DeepSolar64 »
Alex,
I thought at first these were taken in Continuum until I read your post. The supergranules of the lower chromosphere look a lot like the granules of the photosphere but are a bit larger. Your resolution is excellent here! Very nice images!!
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Excellent work, Alex.
I also thought I was looking at the photosphere in that first image until I noticed the finer detail. Absolutely stunning capture!
Jochen Maes
Belgium
https://www.jochenmaes.com
Has thanked: 17925 times
Been thanked: 8891 times
Absolutely incredible imaging :bow :bow :bow I presume this is the Photosphere granulation with faculae visible around the spot. Is this the Baader K line filter? as this only shows the photosphere with enhanced faculae, however, you confuse me with 296nm?
krakatoa1883
Has thanked: 153 times
Post by krakatoa1883 »
Fantastic granulation detail :bow
allhoest
Post by allhoest »
Hi!
Thanks for the comments.
Yes, I used a Baader KLine filter at 396nm (not 296nm!).
CS
Alex.
sulcis2000
Has thanked: 2 times
Been thanked: 477 times
Post by sulcis2000 »
TOP!
Alessandro Bianconi
________________
Celestron C14HD Edge
Celestron C14XLT made in USA
Refractor 228 F8 Truss Tube with D-ERF 110mm
Sharpstar 76PHED
Daystar Quark Chromosphere version
Daystar Quark Calcium H
Starizona Hypestar V4
10 Micron GM2000HPS II Mount
Ioptron CEM120 Mount
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
Basler Aca1920-155um
ZWO ASI462MC
Celestron Skyris618M
grimble_cornet
Been thanked: 47 times
Post by grimble_cornet »
Amazing resolution!
Mike Garbett
Been thanked: 4957 times
Post by eroel »
Alex:
Superb resolution.
LeoD
Has thanked: 1277 times
Been thanked: 1070 times
Post by LeoD »
Incredible images! All together, setup, high altitude and the author of course, gives a fantastic result!
regards
Leo
allhoest
Post by allhoest »
Thank you again for the comments.
Leo, you would wonder my setup: the mirror is an old mirror from the 80's which has been converted to solar, the truss and other parts are second hand, which I adapted a bit in my garage.
The old F6 optic looks to be good and I have a good secondary also.
I should give a try with this setup in my area.
CS
Alex
