this is the first light of the Lunt CaK 1800 star diagonal module I received on Friday. Before I use Baader K-line only and I'm very impressed now!
A full disk in a prime focus is of 2 images, because of 174 sensor.
Close up of the same AR made with similar scale: CaK with TZ-4 telecentric (seems works Ok in Ca also, but with a central reflection spot that I'll try to get rid later) and H-alpha with QuarkChromo. Another H-alpha is AR12772 near NW limb. 130mm.
I'm curious now how to protect in a better way Ca filter from direct sunlight in case of a larger aperture and to narrow a bandwidth
regards
Leo
August 22 FD CaK H-alpha AR12772
- Has thanked: 1262 times
- Been thanked: 1057 times
- CaK FD
- Sun_20200822 111112_cAI2iPs c.jpg (1.1 MiB) Viewed 601 times
- CaK SE quadrant
- Sun_20200822 112159_AIPs cr2с.jpg (658.54 KiB) Viewed 601 times
- 70% scale SE quadrant
- Sun_20200822 132933_AIPs70.jpg (292.04 KiB) Viewed 601 times
- AR12772
- Sun_20200822 134104_AIPsRT.jpg (921.42 KiB) Viewed 601 times
- grimble_cornet
- Been thanked: 47 times
Re: August 22 FD CaK H-alpha AR12772
Impressive set of images Leo.
The Lunt CaK unit is a great bit of kit and I'm sure you will be blown away once you use it on a disc with more features. My unit is the CaK1200 and I use it with a Tal 100mm f10 most of the time. In poor seeing I step it down to 80mm or even 60mm but on good days I use 100mm and a x2 or, on very good days, even x2.5 Powermate when it shows superb detail.
Mike Garbett
Mike Garbett
- Been thanked: 16691 times
Very nice images with excellent detail. I love the FD CaK image and that filament shows well in that SE AR. It's all but gone today.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- JochenM
- Been thanked: 1619 times
New toys are always exciting!
As far as using the module in larger apertures (up to 150mm); I personally just put a Baader Blue CCD filter in front of it (acting as a small ERF if you will). Works just fine.
- Has thanked: 17667 times
- Been thanked: 8787 times
Wonderful to see the excitement of seeing the Sun in a different light, your close ups show just what this super instrument can do
I agree with Jochen as I use the Baader blue too.
- Been thanked: 4904 times
Thank you so much
I was so excited about the new toy that I exaggerated a bit with the x4 and not considered sampling at all. Despite a lousy seeing.
to Mike, Jochen and Alexandra: thanks, seems I could use any blue filter from LRGB set, couldn’t I? I see also about K-line in front of or even instead of front part of Lunt CaK module in the "newton T300" thread here at SC.
Leo
Leo
- Has thanked: 8415 times
- Been thanked: 8161 times
Excellent images, Leo.
