Time: 1:00pm. Temp 81F. Skies overcast with thin clouds.
Orion 70mm Solar Telescope. 25X and 50x ( WL )
No detail at all visible at 1:00pm. The disc is cue ball blank. High thin clouds give it a frosted-over look. Going back later at 1:24pm I was just able to see a facular region just off the NE limb. No other detail visible.
August 27 2020 Observations. WL Only
- Been thanked: 16694 times
Re: August 27 2020 Observations. WL Only
That AR in the NE, is quite faint and doesn't yet (or ever) to be more than that James.
But then aagain who knows.
- Been thanked: 10247 times
Thanks James. I'm back home again at some point over the weekend so hope to get the scopes out for a look then.
You'll probably do better than I will. It looks like rain here for at least the next couple of days.marktownley wrote: ↑Thu Aug 27, 2020 7:24 pm Thanks James. I'm back home again at some point over the weekend so hope to get the scopes out for a look then.
- Been thanked: 8791 times
You did well to catch a white light look even if it is so quiet
